Acceleration issue
Old Jul 13, 2016 | 05:05 PM
Nigma's Avatar
Nigma
Acceleration issue
1989 F-250 Custom V8 351W 5.8L
Vehicle starts right up but won't accelerate in 1st or 2nd gear. Has trouble reversing without dieing. I know the catalytic Convertor is clogged, is this the only thing that would cause this issue? Could the EGR valve be stuck open or closed?
Even if it's in drive and I hold the brake all the way and push the gas pedal RPMs won't go up. In park the RPMs go up just fine. Please help thanks
Old Jul 13, 2016 | 05:14 PM
Nigma's Avatar
Nigma
Constantly smells like gas and get very crappy mpg
Old Jul 13, 2016 | 05:59 PM
Conanski's Avatar
Conanski
How do you know the cat is clogged?
What is the fuel pressure? Low fuel pressure is the most likely cause.
Stuck EGR won't cause your problem, it would stumble at idle but clear up at rpm
While you're at it pull codes and post up what you get.
Old Jul 13, 2016 | 06:01 PM
Nigma's Avatar
Nigma
The cat gets red hot after a little bit of driving. I don't know how to pull codes even reading the guides on engine off key on type stuff. Paper clip and all that
Old Jul 13, 2016 | 06:21 PM
Conanski's Avatar
Conanski
That could be all the extra fuel that the motor is getting, go get yourself an Equus 3145 code reader.. it's 20 bucks or something that's all and it will eliminate all the guess work.
Old Jul 13, 2016 | 06:22 PM
Nigma's Avatar
Nigma
Would they sell this at orielys or autozone?
Old Jul 14, 2016 | 08:09 AM
rla2005's Avatar
rla2005
Da 'Zone does for sure: Innova/Ford OBD1 code reader 3145- Read2Reviews onInnova #3145
I have seen Equus and Innova brand name used for the same tool.
Old Jul 14, 2016 | 08:29 AM
Nigma's Avatar
Nigma
Last night I installed a tachnometer just for fun. Took a short half mile drive down to the store. Came out started the truck up and all my lights went out, interior & exterior, except the front right headlight. So that's cool LOL
Old Jul 18, 2016 | 10:37 PM
Beanscoot's Avatar
Beanscoot
Also check the fuel pressure regulator. The diaphragm can fail in it allowing fuel to be sucked into the intake manifold directly.
It's easy to test, just disconnect its vacuum line from the intake and apply suction to the line. If fuel comes out, it's no good.
Old Sep 21, 2016 | 02:38 PM
seschenburg's Avatar
seschenburg
Check your codes, definitely, but your cat shouldn't glow. Back pressure can affect intake, etc. so if your exhaust isn't flowing your O2 sensor isn't able to do it's job, or may not be working anyway, and it could be telling the computer to run rich. Richness = high fuel usage. If it's high enough you can smell it. Test your backpressure, or if you know the cat is truly clogged, replace it. You can also disconnect your exhaust and run it for a bit that way to see what difference it makes.
d_rich8807
Sep 21, 2018 11:21 AM
lovethosefords
Oct 28, 2017 10:26 AM
misterbond
May 24, 2017 05:53 AM
AndeyHall
Nov 14, 2010 10:22 PM
CaliFordDood
Nov 9, 2008 07:19 PM
