cleaning question
Old Aug 18, 2003 | 10:14 AM
seans64''s Avatar
seans64'
cleaning question
im trying to figure the best way to clean a very thin layer of rust off the piston walls,but its not much,any ideas on cleaning soulutions or anything..motor has a rebuild but has been sitting and i dont wanna tear it down,anything helps,thanks sean.....
Old Aug 18, 2003 | 07:11 PM
horsepuller's Avatar
horsepuller
FTE Leadership Emeritus
FTE Emeritus
cleaning question
Use 'Scotch-Brite'. That's those green pads like you see on the backs of kitchen sponges. You can get the Scotch-Brite pads at a paint store. It's not overly abrasive and won't damage the honing in the cylinder bores. I've even seen oilfield mechanic's use it for cleaning up plain bearing inserts. Keep the work area moist with solvent , WD40, Liquid Wrench or something similar.
