Sponsored by: Real Truck
SD wheel offset question
Old Jul 12, 2016 | 04:32 PM
smlford's Avatar
smlford
Hi-
I'm building an expedition trailer to haul my gear into the back country and I want to use the same size tires that I have on my SD truck so that I will have in effect two extra spares should the need arise....
So I will be going with 18" rims but want to confirm what the offset is. I've read several different answers but the most prevalent seems to be +40 to 44mm.
Is that correct?
Thanks!
Old Jul 12, 2016 | 07:49 PM
street rodder's Avatar
street rodder
You can usually pick up the stock wheels on EBay.
Old Jul 12, 2016 | 11:44 PM
RainDesert's Avatar
RainDesert
+40mm is the stock offset for an 8" wide factory wheel on 2005+ trucks. I have never found them aftermarket with that much offset. I have seen a lot in the +20 ranger which should work fine if you need them.
luisv
Aug 18, 2016 03:50 PM
fishbones182
Aug 24, 2015 01:58 PM
cpye2
Oct 8, 2013 07:14 PM
diver45
Dec 17, 2007 04:12 PM
IL6fan
Dec 16, 2007 10:46 AM
