Surging noise while driving
Old Jul 11, 2016 | 10:13 PM
Amicus's Avatar
Amicus
Gentlemen,
I have a 45 min drive to work every day, all highway. Lately on the way home in the afternoon I have been experiencing a surging noise that seems to just happen while I'm doing hwy speeds. It sounds to me like the fan is tuning on and off. Is that possible? It comes on for a few min. And then off again. I have new icp ipr cps. New oil and filter and fuel filter.
Also I'm still having a battery light on and off issue while I'm driving. Is possible the two issues are connected. I plane on doing extensive search for a bad wire this weekend. Batteries and alternator have checked out and are fairly new. Any advise is greatly appreciated.
Old Jul 11, 2016 | 10:28 PM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
Your location says "hondo" and if it is hot in "hondo" it is entirely possible that the fan it coming on and going off based on the ambient and road surface temperature. My fan typically does not come on unless it is hot out and I am towing, but each truck has its own personality.
Someone with a lot more sage type advice will be along shortly, this is just my opinion.
Old Jul 11, 2016 | 10:36 PM
Amicus's Avatar
Amicus
Yes, Hondo. Gods country please don't drive through it like hell, as the sign reads.
Forgive my ignorance, i assumed the fan was always on while driving. Does it engage on and off depending on temps?
Old Jul 11, 2016 | 10:45 PM
z31freakify's Avatar
z31freakify
Yes the fan clutch has a thermostat that locks the clutch fan when it reaches a certain temp.
Old Jul 11, 2016 | 11:04 PM
Amicus's Avatar
Amicus
Well, I didn't realize that. I just don't every remember hearing that noise before.
Old Jul 12, 2016 | 09:19 AM
white Buffalo's Avatar
white Buffalo
If you have a way of monitoring your oil temp you can kinda get an idea of the temps when you are experiencing the noise/surge. The fan clutch is filled with a gear oil that will allow the fan to engage more as temperature increases. When towing during the summer up bigger grades it can fully engage and sound like a mini hurricane under the hood.
bigdawg460
Feb 6, 2011 04:48 PM
G FELL252
2004 - 2008 F150
Jul 1, 2010 03:27 PM
78sharpshooter
Jul 8, 2007 03:13 PM
ar29456
Jan 12, 2006 12:20 PM
agent614
Jun 12, 2005 09:44 PM
