In my case the answer was a little out side the box. I used Oak.
This is before I stained and antiqued the wood and added all the strips of oak to complete. I will try to get a completed picture in a day or two.
I have the same question. I still have the original headliner so I was thinking of using it as a template, and getting some matte board from a art supply store, then covering the matte board with some vinyl or headliner material.
Kudos to Jim, that is a very original idea and great craftsmanship on that wood. It looks great and is a unique, individual touch. I could go for something like that but I have neither the woodworking skill or patience for such an endeavor. Not to mention I'm cheap , thus I still cruise around headlinerless.
I bought a 4'x8' sheet of pebble-grain plastic used for showers, laboratory walls, etc. It's about 3/32" thick and appears to tolerate a compound bend pretty well. I made templates out of my old pieces and will cut new ones. I intend to modify the original design to extend the main (top) piece forward and screw it to the flange rather than use those hokey clips. I'm making door panels too. I haven't started cutting yet so no pictures...
Eric
Thanks Tom. It really was not to difficult to do. I was able to get the strips of Oak in 4 foot lengths for under $4 each at Home Depot. http://www.homedepot.com/p/1-4-in-x-...7410/207058958 Total cost is well under $100.
Yes, I am waiting for those pictures too. Very creative idea, and now you've got me rethinking my plan. Great work! Are the firring strips fastened in the center only, or at the ends as well?
I used templates and FRP (fiber reinforced plastic). Perfect material for this. I left off the lower pieces because it looked good to me painted only. Pics are before rest of interior and trim complete.
I like both approaches so far, the oak and the plastic.
I have a complete original headliner, although slightly warped from a squirrel storing nuts above it. I'm considering using the original headliner as a template to make a headliner out of natural cork. Comes in sheets/rolls the same thickness, and I have some left over from a different project. The replacement headliners are costly, and honestly, I don't find them very attractive.
So if I do that, it's time not money since already have the material. I think the cork would fit with my color scheme, and also I could wax or seal it afterwards. I like cork. My home office desk is made of it.
Cyber searched and unable to find local supplier of the product, came across an item referred to as Fiberglass Reinforced Wall Panel, at Lowes Home Improvement, comes in variety of different textures and colors. Likely check it out and see if same/similar; although don't believe it works well in forming bends?, certainly save few $ in the cost of shipping 'oversized' package? http://www.lowes.com/search?searchTerm=fiberglass+reinforced+wall+panel[/url]
It looks great! I'd love to see a few more pictures and how you integrated the light inside
The light is a vintage glass lens find from eBay and is mounted on the lip above the rear window. I like it better than the factory plastic one.
The oak strips are currently only attached at the center. I shaped a piece of 2"X2" material for the center to attach to the factory roof support. I attached that with three bolts using rivnuts on the steel support minimizing holes in it. Therefore, the strips are screwing into wood except on the last piece close to each door. I may add a small dab of double sided tape to the rear ends to better hold their position, but for now they do not seem to be moving around.
Originally Posted by john jamieson
The oak strip idea would be a great addition if you have a wood bed too.
