Newbie Code 12 ABS HELP
Old Aug 8, 2024 | 08:03 AM
z31freakify's Avatar
z31freakify
The OP replaced the brake fluid reservoir and that fixed his problem.
also check your e brake switch and wiring, also make surebthe E brake is actually disengaging.
Old Aug 8, 2024 | 11:33 AM
fordman67's Avatar
fordman67
I'm ordering a reservoir tho my testing did not lead that way initially. The brake light was inop and I had cluster out for my health. It works now lol. Everyone says pull the bulb out of abs but I'm just not that guy.
Old Aug 8, 2024 | 12:21 PM
farmert's Avatar
farmert
Originally Posted by fordman67
I'm dragging this relic up. I'm battling it on my rig and I'm about to burn it to the ground honestly.
I was pulling a trailer with faulty wiring one time. After that my anti lock light was on. Turned out a fuse was blown in the in cabin fuse panel. I don't recall which fuse it was, maybe #15, but replacing the blowen fuse made the light go out. Hope it is that simple.
Old Aug 8, 2024 | 10:56 PM
fordman67's Avatar
fordman67
The fuse associated with the red brake warning light is good akaik. I gou the light working with Park brake application. . I pushed the float down with a screwdriver but light is inop for that. Will that cause this? Heck idk lol. The code is for light On causing abs. I guess I'm going to do a master for this plus that's literally the only thing in the brake I have never replaced in all these years.
Old Aug 9, 2024 | 10:47 AM
knottyrope's Avatar
knottyrope
float down should trip a light on dash to tell you low fluid
Old Aug 9, 2024 | 02:08 PM
farmert's Avatar
farmert
Just to be clear, the light in my case was for the antilock or abs or what ever they call it, not the red brake light.
Old Aug 10, 2024 | 02:30 AM
fordman67's Avatar
fordman67
Yea that's the current direction I'm going
Old Aug 10, 2024 | 02:31 AM
fordman67's Avatar
fordman67
Yes. The crazy part is code 12 is referring to a brake fluid level low or mother things having to do with the brake indicator funny enough.
Freddie Murphy
Jul 7, 2016 02:19 PM
Bordeauxman
Dec 22, 2014 04:00 PM
mdec950
May 6, 2012 01:13 PM
jocasseesam
May 9, 2006 12:56 PM
fordbidden dreams
Bronco II
Nov 14, 2003 02:26 PM
