Sponsored by: Real Truck
Error code from obd port
Old Jul 9, 2016 | 11:30 PM
Bpickett's Avatar
Bpickett
So I just bought a 2003 f250 v10 and I've plugged in my code reader and it couldn't get any info, so I took it to auto zone and they got an error code. I took a test lite to each little connection on the port with the ignition on and only got power to some of the metal connections on the port. So I'm wondering if all the little connections should have power? If so where should I start to look to find the problem?
Old Jul 10, 2016 | 07:18 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
So when you went to Autozone the port worked. Why are you testing it? You've already proved it works fine. Something is wrong with your code reader, not the port.
Old Jul 10, 2016 | 11:18 AM
Bpickett's Avatar
Bpickett
No... Autozones reader did NOT work.
Old Jul 10, 2016 | 11:25 AM
projectSHO89's Avatar
projectSHO89
That is NOT what you reported in your initial post, you said you "took it to auto zone and they got an error code. " That implies that it worked.
Try explaining things specifically, it makes things easier.
Did you check the fuse for the cigar lighter?
Old Jul 10, 2016 | 11:31 AM
Bpickett's Avatar
Bpickett
Sorry, error code as in they plugged it in and it said error because it couldn't get a good connection. And I've tried a couple of different fuses and they were all good. However I don't know the exact fuse to check, I've heard people say its 2,3,4, and 12
Old Jul 10, 2016 | 02:15 PM
projectSHO89
See the owner's manual for fuse information. If you do not have one, see my signature and get one.
Dimalex2
Apr 11, 2017 07:16 PM
VTX1800rider
May 21, 2013 07:18 PM
wrk4no1
Feb 21, 2010 08:42 PM
itsafordguy20
Jul 26, 2008 09:49 AM
