how high can I go?
I guess I am going to have front springs re-arched and have a new set built heavy for the rear so I can kick that block out. I looked into it and this I can have done relitively cheap, but how high can I go before I have to put a new pitman arm on. I heard they were 200 bucks or better for a good one and i really dont want to spend that much. I was told you can go a total of 5'' without changing the p-arm,but if so is this just going to put it in a bind to where it will go out in a year anyway or what? Any opinions good or bad would be greatly appreciated. Thanks alot
I'd spend the $200 on the pitman arm, although it may not be needed, in order to save your steering box. Leaving the stock arm on with a lift causes additional stress on the box, and replacing them is a real pain - a real expensive pain at that.
