steering part
Old Aug 16, 2003 | 11:41 PM
msgjvh's Avatar
msgjvh
steering part
I have searched the net high and low and I can't find the name of the bolt I need. Anyone have a parts drawing? I need the retaining bolt between the rag joint and the steering box. Kinda like a bicycle seat bolt.
Thanks
Old Aug 17, 2003 | 12:58 AM
68back's Avatar
68back
steering part
i am not sure exactly what a rag joint is but i have a pretty detailed parts catalog in front of me right now
Old Aug 17, 2003 | 01:08 AM
68back's Avatar
68back
steering part
after going back and reading your first post i now know what you are talking about.I had the same problem about 1 year ago,and I got the bolt from NAPA so you might be in luck.
Old Aug 17, 2003 | 01:15 AM
msgjvh's Avatar
msgjvh
steering part
do you per chance recall what kind of bolt it was??? Fine or standard thread and length? Thanks that gives me confidence that I may not have to search the junkyards.
Old Aug 17, 2003 | 01:25 AM
68back's Avatar
68back
steering part
If I remember corectly, I used a 5/16 standard SAE thread bolt to get by with,but I'm not positive.
Old Aug 17, 2003 | 02:11 AM
longview1's Avatar
longview1
Banned
steering part
Hey dude,
I just went out and checked mine out, its eityher 7/16 or 9/16 (to hard to tell the way it was, but im thinkin probably 7/16)
Its about 2 inches long, and the head of bolt isnt your basic 6 sided one, its like the old LGD beer cans with all the edges.
Hope that helps a bit man.
Old Aug 17, 2003 | 03:23 AM
msgjvh's Avatar
msgjvh
steering part
Thanks I appreciate you help.
Old Aug 17, 2003 | 08:12 AM
Torque1st's Avatar
Torque1st
Posting Legend
steering part
I believe you are talking about a specialized fastener used for the steering "rag joint". You can cannibalize another rag joint to get one.
Old Aug 17, 2003 | 08:20 AM
laptopgeek's Avatar
laptopgeek
steering part
..a picture is worth a thousand words... look at my site at <http://www.beedzncomputers.com/truck...r/coupler.html> ...do you see the part here?...
Old Aug 17, 2003 | 08:25 AM
Torque1st's Avatar
Torque1st
Posting Legend
steering part
I didn't see the part I am talking about...
I believe he is looking for the bolt that goes thru the coupling. You can see the coupling next to your palm.
Old Aug 17, 2003 | 09:44 AM
ranger429's Avatar
ranger429
steering part
if it is the bolt i am thinking of it has a flat side on part of it to keep the shaft from spinning freely. motormite or HELP (same company) reproduces those and they are available at most auto parts store's
Old Aug 17, 2003 | 07:42 PM
msgjvh's Avatar
msgjvh
steering part
I did not see the bolt that compresses the coupling on the steering box shaft. I went to NAPA and used a 3/8 fine thread 9/16 head bolt with lock washer. It is working just for now. I will make a trip to the junkyard within the week to get the proper bolt. Bizarre how the other one fell out. But this one got the truck home so I think it is solved for now. Since the carb rebuild the engine is running much better but I have to lower the idle. I will do that later in the week also.
Thank you for everyones interest! It's a great comfort knowing there are others out there that can help at the touch of a keyboard.
Old Aug 17, 2003 | 08:45 PM
Mil1ion's Avatar
Mil1ion
steering part
It would be the 7/16" (12 point) bolt that that holds the couplng to the shaft ...would it ?
Old Aug 18, 2003 | 12:41 AM
msgjvh's Avatar
msgjvh
steering part
7/16th thread was too big I believe. The one I used was 3/8's. Bolt head is 9/16 and the thread count was 24. I do believe the orginial is a 12 point head.
Old Aug 18, 2003 | 12:17 PM
Mil1ion's Avatar
Mil1ion
steering part
The ones I have take either a 11mm or 7/16".
Would a photo help ?
