Towing ??
Old Jul 7, 2016 | 09:34 AM
2track's Avatar
2track
Towing ??
Had 08 scab 6.5 ft. bed 5.4 with 3.73 rear end towed a 29 ft. camper no problems. Now using a 13 screw 5.5 ft. bed 5.0 3.73 gears towing same trailer but this truck seems to pull with more side slop then the older truck. what gives??? Both have tow package. Do I need a rear sway bar or any other idea's. Thanks
Old Jul 7, 2016 | 12:28 PM
Thunder:Raven's Avatar
Thunder:Raven
There could be any number of things contributing to that. Tires or tire/wheel combination being the main one that comes to my mind.
Old Jul 7, 2016 | 06:54 PM
WXboy's Avatar
WXboy
Main one that comes to my mind is your significantly shorter wheelbase now. Why didn't you get another 6.5' box?
Old Jul 7, 2016 | 07:01 PM
eriebasin's Avatar
eriebasin
I believe an scab with the 6.5 bed is the same wheelbase as the screw with the 5.5 bed. 145". A screw with 6.5 is 157" I think.
Old Jul 7, 2016 | 10:15 PM
meborder's Avatar
meborder
Do you have pics of your camper hooked up that you could post?
If I were to guess, id say you probably just need more weight on the front axle. Why your old truck wasn't as sensitive is anyone's guess, but tightening up the bars is free and thats where id start.
If that doesn't work then look at sway control.
What kind of hitch are you using?
Old Jul 8, 2016 | 07:50 AM
2track's Avatar
2track
Towing ??
Thunder I'm thinking along your lines about tires being the problem. As for wheelbase this truck is actually .5 inch longer then the scab from 08. and I'm using a reese weight dist. with sway control so that's not the problem. I've pulled this same trailer for many years with 4 different trucks from 250 diesels to the current 150 and never noticed this behavment, so I think I'll go with the tires. thanks all
Old Jul 8, 2016 | 09:49 AM
WXboy's Avatar
WXboy
Ok I totally missed that your first truck was a scab and not a screw. My bad. Yeah, tires can be a big deal. Hopefully you figure it out easily.
Old Jul 17, 2016 | 05:52 AM
hammer65's Avatar
hammer65
My 2007 had LT tires, while my 2011 has P tires, I suspect tires are your problem.
I have a 23 foot Jayco TT with sway bar, WDH and it squirms a bit.
dooger54
All Things Towing
15
May 31, 2016 04:24 PM
Miller
All Things Towing
30
May 19, 2008 04:58 PM
abaker
2004 - 2008 F150
Sep 26, 2007 12:14 AM
JRoper
Apr 4, 2005 12:52 PM
sundropg
2004 - 2008 F150
18
Mar 20, 2005 09:18 PM
