Good Steering stabilizers?
Old Jul 6, 2016 | 09:44 PM
bamcq's Avatar
bamcq
Hi all,
I'm fairly new to FTE and to owning a ford diesel in general, I have a 2015 f250, have had for almost a year and has about 53K miles on it (bought it used at 18K). I have been looking at different things to change/upgrade to improve my overall performance and handling now that I'm starting to see some of the stock stuff wearing out. I just finished upgrading my shocks from stock to the 5100s but was also looking into steering stabilizers to help improve my handling. Was wondering who makes a decent stabilizer? dont really care who the brand name is as long as it's a good quailty one and isn't really prone to fail from snow, road salt, and other road junk getting inside? Also, I don't have a lift or leveling kit on mine just stock suspension so would it still be beneficial to have dual stabilizers or would it just be more of a waste of money? Been doing some research and haven't really found a good answer yet. Thanks in advance for any help!
Old Jul 6, 2016 | 09:54 PM
cyncwby's Avatar
cyncwby
Well honestly I've had trucks most of my adult life, 2WD/4WD...gas and the last 2 were diesels. I have leveled a couple of my trucks but never put a so-called lift on one. I have never used a steering stabilizer nor have I felt I needed one.
If you are experinencing a problem then I would have it checked by a front end shop rather than band aide it with a stabilizer. If you still think you need one then Bilstien would be the one.
Old Jul 6, 2016 | 10:01 PM
bamcq's Avatar
bamcq
Okay thanks for the advice. I know I had an alignment done back when I first got new tires on it but dont really remember the last time I've gotten one done since now that I think about it. Appreciate your time.
Old Jul 7, 2016 | 12:28 AM
WK15's Avatar
WK15
Carli / Bilstein 7100 Steering Stabilizer
Old Jul 7, 2016 | 01:35 AM
2civicrr's Avatar
2civicrr
I went with the Bilstein 5100. Made a huge improvement.
Old Jul 7, 2016 | 07:24 AM
bamcq's Avatar
bamcq
Okay thanks! I'm going get alignment done first and then look at the stabilizer. Did y'all run dual stabilizers or just the single one?
Old Jul 7, 2016 | 07:38 AM
SavageNFS's Avatar
SavageNFS
The single Carli is what I ran on mine and it performed perfectly.
Carli 08+ Ford Stainless High Mount Steering Stabilizer
Your truck already has a steering stabilizer on it and the Carli replaces the stock one. It's a direct fit and works great. It is basically a custom valved Bilstein 7100
Old Jul 7, 2016 | 08:09 AM
bamcq's Avatar
bamcq
Yeah I had saw the that came stock.. Figured after what my shocks looked like after I took them off that steering stabilizer was probably in just as bad a shape. Kinda nice that they're alittle cheaper than bilsteins or at least on the website link you sent me they were. I'll look more into them. Thanks, appreciate the info!
Old Jul 7, 2016 | 04:00 PM
Beedub109r's Avatar
Beedub109r
I went ProComp
I didn't like the bump steer on a brand new truck. I was upgrading shocks anyways so I got the ProComp dual stabilizer. Works well and improves/ reduces bump steer. My truck is not lifted and is a stock 2016 FX4.
http://www.4wheelparts.com/Pro-Runne..._pn=EXP222582Z
Old Jul 7, 2016 | 08:24 PM
bamcq's Avatar
bamcq
Cool thanks! Getting the front end done next week and then will go from there thanks for the input!
Old Jul 7, 2016 | 09:06 PM
doublenot7's Avatar
doublenot7
I have the Ford stock single stab and a dual pro comp.
Old Jul 7, 2016 | 10:26 PM
bamcq's Avatar
bamcq
Inhad saw somewhere not on here but I YouTube I think commenting on having dual stabilizers on trucks and it actually making it a lot harder when driving in snow and ice.. Idk if you live in a snowy state but if you do have you ever had that problem. I live in wv and after last years 3ft of snow I'm really nervous about taking that risk with putting on duals. But again I dont know the merit if that's actually a true statement or not. Just curious
Old Jul 8, 2016 | 12:17 AM
2civicrr's Avatar
2civicrr
Pro Comp Suspension - Pro Runner Dual Steering Stabilizer Kit - Fits 2005 to 2016 Ford F250/350 4WD with 0 to 8 Inch Lift - 4WheelParts.com
Basically the same deal for me. Stock 2015 F350 CrewCab Short Bed FX4. I didn't like the bump steer. Truck felt a little 'loose' to me in stock trim. Steering just seemed to wander a lot to me. I installed Bilstein shocks & steering stabilizer. Shocks firmed up the ride a little but increased control. Steering was greatly improved.
I also installed a oem rear anti-sway bar. Improved handling quite a bit. I didn't go with the Hellwig for a couple reasons. First, I didn't want to deal with the possibility of a loose rear end in rainy conditions when running empty. Second, I didn't like clamps around the axle housing.
Old Jul 8, 2016 | 08:14 AM
ruschejj's Avatar
ruschejj
To the OP. Everything seems reasonable about your needs and wants regarding equipment but I feel the need to say one thing.
There really should not be a need for any alignment or front end work at all on your truck. The SD is very solid up front and any parts around the front axle should perform like new at least until you reach 150,000 miles. Been my experience anyway on 5 or 6 of them. I mean brakes and shocks/stab do wear out and that's normal, but I would expect that you would not need to mess around with anything else for a long time.
Old Jul 8, 2016 | 08:40 AM
bamcq's Avatar
bamcq
Hmm that's very interesting. I'm just trying to get overall knowledge about how these machines work and also why I have the wobble in the steering wheel as bad as I do. I looked at all my front end parts or at least the ones I'm familiar with and everything did look pretty good like you are saying no noticable problems. only 2 things I could come up with was alignment needing done or steering stab needing replaced or both and after seeing my shocks id be very surprised if the stab is still in good condition. I was thinking of an alignment because my truck of that wobble and that its been pulling to the right. Now I am to the point where my tires are getting where they need replaced which might have something to do with it I know but they only have about 30K miles on them. Also it's not like I have some cheap tire, they're bfgs KO2s and my gf has had them on her f150 ran them last 10 years and never has seen them wear out as fast as mine has. Would the stab really control that much of the steering in regards to the wobble..? I really appreciate everyone's help and responses so far. Has been very informative so thank you
