Grounds!
Old Jul 6, 2016 | 05:41 PM
Gary Lewis's Avatar
Gary Lewis
Grounds!
This is just a quick post to let you know how critical grounds are.
I've been looking for the culprit that is keeping the alternator on my boat from bringing the voltage up to snuff, meaning 14.2v. It is a 70a alternator, but I'm only seeing it throw 30a and the voltage is only coming up to the mid-13's.
So, I went looking for things and found the ground wire to the alternator broken off. And, with the paint on the alternator and 30 amps being thrown there was .8v between the ground wire and the stud. So, the case was at 14.2v but the battery was at 13.4v.
GROUNDS ARE IMPORTANT!
Old Jul 6, 2016 | 05:44 PM
Festus Hagen's Avatar
Festus Hagen
Methanoholic
Amen!
-Enjoy
fh : )_~
Old Jul 7, 2016 | 01:55 AM
Blackduck59's Avatar
Blackduck59
A case of too short a cable and no give for a little vibration?
Was the original just crimped or soldered as well?
I solder all connections on our boat and being an Alloy hull good grounds are on the top of the list of must haves.
Cheers Steve
Old Jul 7, 2016 | 07:23 AM
Gary Lewis's Avatar
Gary Lewis
The cable seems to be long enough, but it was just crimped. I will solder the replacement back and use adhesive heat-shrink tubing on it, as I do with all "smaller" wires, meaning anything smaller than about 8 gauge. The larger sizes I crimp with my hydraulic crimper.
Redworks
Jul 5, 2015 08:28 AM
Sarco3
Mar 26, 2015 09:03 PM
Jesser02EX
Jan 2, 2015 05:37 PM
kykell2
13
Feb 11, 2013 04:40 PM
Milwaukee1979F150
26
Feb 9, 2012 01:13 AM
