Ok so I have a 1995 F150 4x4 4.9 5spd. A few months back I started replacing the head gasket on it and I finished up the job about a week ago. I installed a new FelPro head gasket, new cylinder head, and replaced a ton of other gaskets during the project.
Well unfortunately now that it's all back together my truck is still blowing white smoke out of the exhaust. I let it run for a good amount of time since the fix and it's not clearing up. I torqued everything to spec and took my time on the entire job.
I can't possibly understand what else it could be other than the chambers inside the block potentially having a crack between them? So far the oil still looks clean to me, no sign of mixing. When I shut off the truck today after running it a bunch of coolant from the radiator rushed into the coolant overflow tank. Let me know if I'm leaving out any information. I'm really at a loss at this point looking for any help, thanks in advanced!
Hard to say what the smell is, but I wouldn't say it smells sweet and I haven't done a compression test. I guess that would be my next option, but the smoke isn't blue so I figured it probably isn't oil.
Did you check the head for straightness before you put it back on? The long heads on inline engines are more likely to warp if severely overheated (because an amount of bend that wouldn't be a problem over the length of a 4cyl head is a problem when it's 150% as long)
Originally Posted by Festus Hagen
Usually coolant smells sweet and white out the pipe ...
Sounds like you need to do a leak down test on the cooling system.
I don't know the i6 well enough to know if or where they crack ...
-Enjoy
fh : )_~
Exhaust valve seats and other exhaust port areas tend to crack "most frequently" by 300 standards, so practically never. You need to overheat the crap out of it multiple times or have really bad luck to make that happen though. This is an engine that you can accidentally run out of coolant god knows how many times as long as you stop running it before it makes funny noises. I don't recall anyone on FSP with a cracked head. Maybe one or two buried in threads somewhere but I can't recall a single specific instance. There's talk of the AIR injection head being weaker in this regard because the ports cause stress risers that cause problems when overheated but to my knowledge there's no examples of this happening in a lab, on a dyno or in the real world.
Did you look at the cylinder walls while you had it torn down?
Run the tests, compression and leak down. You may have to bar the engine a few times to make sure the rings aren't sealing above a cracked wall, but either way a cracked cylinder will likely show up in either test.
It's probably straight but I'd bet that the odds of any one head being passed along even if it's borderline out of spec or just missing the check altogether (when you reman enough heads things happen, nobody has perfect QC) are probably about the same as cracking the head in the first place (really, really low but still possible).
It's not even rebuilt it's an aftermarket head from a company that cast them new. I figured it would be straight but I guess it is possible for a bad one to slip through.
Thank you, Thank you very much!
I always thought they were kinda bullet proof ...
