Front axle Identification
Old Jul 5, 2016 | 08:24 PM
FordF1004x4's Avatar
FordF1004x4
Hi all.
I bought a 1960 F100 4x4 about 2 months ago. I am trying to find parts for it since the PO kind of *******ized it. It has a 440/727, 14 bolt FF rear, and possibly a dana 60 front(closed knuckle). It still has the original dana 24 transfer case.
So the front axle has that reads 4.09 D4TA SA, BOM is 603480-1. I went to dana's site and entered the BOM and it does not exist. The weird thing is the rear axle is 63 WMS which means it came from a C&C type truck. Maybe the front did also? I just took the drum off and it has no screws like I read about. It also has 12x3 brakes. Any help would be appreciated.
Plans are to fix it up and when the 440 dies I want to put a 460 with a 4 speed auto. Overdrive would be pretty sweet. I am clearing the rust off of it. Welding a few plates where the PO cut out the bed. Needs windshield and both side windows replaced, new tires and rims. I needed a project and I got it!!!
Old Jul 5, 2016 | 09:17 PM
truckdog62563's Avatar
truckdog62563
Marmon-Herrington Man
Your BOM code is on page 57 at the bottom of the page. It's a 74/75 F-250 HD open diff. Stu
http://www.therangerstation.com/tech..._1967-1978.pdf
Old Jul 5, 2016 | 09:24 PM
FordF1004x4
Thanks! I have searched for a bit trying to find it. The dana site did not even have it listed on their BOM site.
Old Jul 6, 2016 | 10:28 AM
willowbilly3's Avatar
willowbilly3
Makes sense with the D4 number
Old Jul 6, 2016 | 10:35 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by FordF1004x4
I bought a 1960 F100 4x4 about 2 months ago. I am trying to find parts for it since the PO kind of *******ized it. It has a 440/727, 14 bolt FF rear, and possibly a dana 60 front (closed knuckle). It still has the original dana 24 transfer case.
So the front axle has that reads 4.09 D4TA SA BOM is 603480-1
Column left, 19th entry: Dana 44-6EFGH / 4.09-1 / No Free Running Hubs or Limited Slip / 3,500 lbs. Front Axle Capacity.
1974/75 F250 4WD Regular Cab with full time drive. 1973/75 F250 4WD: Front drum brakes are 12 1/8" x 2"
Old Jul 6, 2016 | 08:32 PM
FordF1004x4
Weird. Maybe somebody upgraded it to 12x3" brakes?
Yes it does have the locking hubs up front.
Looking at the dana identification covers, it looks like the dana 60/70. Looks like the 70 has a bit more on top which I don't think mine does.
http://www.differentials.com/technic...identification
Old Jul 7, 2016 | 09:47 AM
NumberDummy
Differential Identification | West Coast Differentials
12" x 3" front drum brakes: 1967/72 F350.
The D4TA-SA ID tag number you posted: Parts catalog says this is a 3,500 lbs. capacity Dana 44-6EFGH .. no free running hubs.
Dana 70's were only available as a rear axle, were only installed in F350's.
Old Jul 7, 2016 | 08:46 PM
FordF1004x4
No free wheeling hubs? Are those the hub lock and unlock so you can make it part time 4x4?
If yes, then mine have those.
75Three90
46
Jan 19, 2016 07:26 AM
66flareside
Aug 17, 2010 06:03 AM
Crew_Cab_78
Jan 3, 2010 12:17 AM
FordPickMeUp
Offroad & 4x4
Aug 29, 2005 06:34 PM
fourfoot23
Jun 6, 2004 09:26 PM
