i beam bolt size????
Old Jul 5, 2016 | 07:42 PM
86f250-rs's Avatar
86f250-rs
I'm looking to get new grade 8 bolts that connect the I beam to the radius arm and coil spring. mine are seized, so I cut them out. lmc truck calls them lower spring bolt, but doesn't show the size. any help is appreciated.
Old Jul 5, 2016 | 07:53 PM
ctubutis's Avatar
ctubutis
Dude... year & application...
Old Jul 5, 2016 | 08:02 PM
86f250-rs's Avatar
86f250-rs
1985 f150 2wd
Old Jul 5, 2016 | 10:25 PM
ctubutis's Avatar
ctubutis
Is the thing you're looking for on this page?
Old Jul 5, 2016 | 10:38 PM
Rusty_S's Avatar
Rusty_S
I think the bolt hes talking about goes through the radius arms through the I beam with a nut to hold the assembly together then the spring, spring retainer, and nut screws down on this bolt to hold the coil spring assembly to the I beam.
Old Jul 5, 2016 | 10:45 PM
ctubutis's Avatar
ctubutis
Heavy sigh... where does Ford show that stuff... apparently not in Suspension... could be with axles, could be with springs, probably not with steering... *sigh*
Old Jul 5, 2016 | 10:47 PM
Rusty_S's Avatar
Rusty_S
I know how that is. Or you go to the proper section based off the number you are looking at for the part number and it says please go to section --- which then has 40 pages of charts.
I'm going to look and see I would assume it would be under suspension
Old Jul 5, 2016 | 10:49 PM
Rusty_S's Avatar
Rusty_S
Section 30 page 12
Part Reference # 388727-S
Old Jul 6, 2016 | 04:26 AM
86f250-rs's Avatar
86f250-rs
Yes, this one. Lmctruck shows it in their catalog under 2wd suspension
Old Jul 6, 2016 | 12:58 PM
86f250-rs's Avatar
86f250-rs
Number 8:
Old Jul 6, 2016 | 03:02 PM
ctubutis's Avatar
ctubutis
Thanks for the picture! I'll try to remember to look tonight unless some other kind soul does it before me.
Old Jul 6, 2016 | 03:58 PM
FuzzFace2's Avatar
FuzzFace2
So you cut it how do you get it out of the beam?
I could not even get the nuts off the 4 beams I have with my impac gun!
I am hopping the setup I have in the truck does not have to come apart for king pin replacement & spindle swap.
Dave ----
Old Jul 6, 2016 | 04:18 PM
86f250-rs's Avatar
86f250-rs
Dave ----
I'm not using the factory I beams. I have the dream beams
Old Jul 6, 2016 | 05:01 PM
FuzzFace2's Avatar
FuzzFace2
cheater
Dave ----
Old Jul 6, 2016 | 09:41 PM
displacement4me's Avatar
displacement4me
It took me Superwrench penetrant, an unregulated ½" air supply, heat, and patience but I got mine out, I wouldn't have cut them. Anyways... I found this in my service manual:
The first hit for ford bolt 388727 took me to this:
https://www.ford-trucks.com/forums/1...rt-number.html
