Engine stalls when accelerator is pressed.
Old Jul 12, 2016 | 07:50 AM
  #46
Filthy Beast's Avatar
Filthy Beast
Holley carbs - if you can turn the mixture screw(s) all the way in and she still runs, the power valve is history. That's straight from the horse's.....mouth = Holley. A blown power valve would cause your plugs to look like they do, a very rich (unburned hydrocarbons) smell and difficult starting - somewhat of a flooded condition.
Your carb takes a 6.5 power valve.
Old Jul 12, 2016 | 08:35 AM
  #47
Ronnief150man's Avatar
Ronnief150man
It's brand new. What would cause it to go out?
Old Jul 12, 2016 | 09:20 AM
  #48
Filthy Beast
A little history on Holley carbs: Back in '92 or '96 Holley decided to use a "blowout protection" valve in their carbs. It's just a little bb sized ball and a spring located in the base of the carb, below the power valve. It's supposed to stop the P/V diaphragm from rupturing when a back fire through the carb happens.
I've found it doesn't always work. I had a little fart through the carb once and the power valve s**t the bed. I drilled it out and never used one again. No problems.
Now to address your question: If the carb sat for awhile the P/V diaphragm could get brittle and crack rendering it useless. A back fire would do it, too...my experience in both cases. The mounting gasket could become gas soaked and leak, could be old and brittle, too.
You might luck out and still be able to re-use the blue bowl gasket on the metering block when changing the P/V.
Old Jul 13, 2016 | 06:26 PM
  #49
Ronnief150man
Thanks for info on carburetor I may be in for a rebuild. I sprayed starter fluid around top of intake and bottom of carb. Also around the piece on top of intake that has vacuum lines hooked to it. The motor dies down when sprayed around vacuum lines. Although very faint I think it dies down when sprayed on drivers side of intake. 😠
Old Jul 13, 2016 | 06:41 PM
  #50
Jklnhyd's Avatar
Jklnhyd
You say that it is a new carb? Very easily could be a worn out vacuum hose. Too tight or too loose on carb torque.
Old Jul 13, 2016 | 07:01 PM
  #51
Ronnief150man
I thought maybe be worn vacuum line. I check tomorrow. Thanks for reply.
Little White
37
Feb 15, 2019 03:46 PM
randre
Jul 26, 2018 08:16 PM
sandsOtime
21
Oct 20, 2015 07:55 PM
Steve A
30
Dec 21, 2004 06:22 PM
fatdaddy
Apr 19, 2002 06:42 PM
