Replace Bulb in Trailer Reverse Light?
Old Jul 3, 2016 | 10:11 PM
HRTKD's Avatar
HRTKD
My trailer uses Bargman reverse lights as pictured below. I would like to replace the bulb with an LED. As near as I can tell that is not possible. It appears that the entire assembly is replaced instead. Can anyone confirm that?
If the bulb can't be replaced then I'm going to polish the lens to remove the opacity, reinstall it back in my trailer and call it a day.
Old Jul 4, 2016 | 06:43 AM
Chuck's First Ford's Avatar
Chuck's First Ford
it looks like a common 1/4 turn bulb... press in and turn.. #1141 or #1156 bulb
its getting the room for your fingers....
Old Jul 4, 2016 | 06:47 AM
RV_Tech's Avatar
RV_Tech
Did you take the lens off to see?
Steve
Old Jul 4, 2016 | 08:39 AM
HRTKD's Avatar
HRTKD
Sorry, I wasn't clear. I can't get the lens off at all. I see no way to disassemble the entire unit. In other words, bulb goes out, replace the entire thing.
Old Jul 4, 2016 | 08:46 AM
BPofMD's Avatar
BPofMD
Veteran: Navy
Usually you just have to squeeze the top and bottom of the lens(close to the frame at centerline) at the same time and gently pull it away from the body of the frame. Or check if you can find a notch to insert a flat bladed screwdriver into and just lift it out.
Old Jul 4, 2016 | 09:27 AM
HRTKD's Avatar
HRTKD
I have been squeezing and pulling with no progress made.
Old Jul 4, 2016 | 11:04 AM
Chuck's First Ford
the few I have worked with
there is 3 or 4 tangs... going into the body/shell of light...
sometimes both hands are needed to squeeze ... and like already stated 1 or 2 screwdrivers...
while squeezing .. also push lens to one longer side.. helping with space for tangs to slide out of slots.
never seen glued lens .. but you know the .... story.
Old Jul 4, 2016 | 11:29 AM
RV_Tech's Avatar
RV_Tech
Can't believe it won't pry off. My best friend in these situations is the wide blade Buck knife I use for prying. Thin blade works better for me than screw drivers.
Old Jul 4, 2016 | 02:50 PM
HRTKD's Avatar
HRTKD
I cleaned it up and put it back on. I tried a number of things to get the lens off and it wouldn't come off. I'm thinking it is designed to be 100% waterproof and is therefore completely sealed and not intended to be opened.
The trailer's owner's manual listed a replacement bulb for that light so I expected to be able to replace it.
I was unable to find a replacement oval reverse light assembly from Bargman. They have replacement brake lights but no reverse lights. If I have to replace it I'll buy a complete LED assembly I guess. So now I have two unused bulbs sitting around.
Old Jul 4, 2016 | 03:19 PM
RV_Tech's Avatar
RV_Tech
No number on it I guess?
Old Jul 4, 2016 | 03:26 PM
HRTKD's Avatar
HRTKD
Yeah, that was the strange thing. The Bargman name was on it but absolutely no product number.
The opacity that I mentioned earlier in the thread was not something I could do anything about. I polished the lens and then realized that the frosting of the lens is on the inside. So I guess it's supposed to be a diffuser. More of a flood light than a spot light. Oh well, now the outside is nice and shiny.
Old Jul 4, 2016 | 03:29 PM
RV_Tech's Avatar
RV_Tech
Man, you are right. that is just plain weird!
Old Jul 4, 2016 | 03:30 PM
HRTKD's Avatar
HRTKD
Just for giggles I'm going to see what Bargman has to say. Inquiring minds want to know!
Old Jul 4, 2016 | 03:56 PM
twigsV10's Avatar
twigsV10
I have disassembled that style of light on my feed wagon... Using a cement feed bunk lol. Peterson MFG model 421R (red) and it appears its glued together permanently.
Old Jul 4, 2016 | 04:49 PM
RV_Tech's Avatar
RV_Tech
Well, there you go. Nothing to it!
Steve
