Flummoxed: Alternator light
Old Jul 3, 2016 | 02:05 PM
mecdac's Avatar
mecdac
Question Flummoxed: Alternator light
I normally read in this section and don't ask questions or start threads in this section, however; I have not been able to find an answer to this condition.
Background:
'01 Excursion 7.3 4WD, 264,xxx miles, batteries less than three years old, new alternator (https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1) , using an Edge Insight for digital readings.
Problem:
I replaced the alternator about three weeks ago, first week all normal. Second week alt/battery idiot light comes on, then to add more frustration it is consistently inconsistent in its reading.
The volts (upon starting) jump around 11.6 - 12.1 when first starting. The light comes on while accelerating and goes off during no throttle while cold.
After warm-up the light will come on intermittently even though the reading is 13.0>, but never during off throttle.
It seems to do this more when cold but it does not completely stop when it's warm. Yes, I don't think that should be a factor but it is a reality .
I'm thinking it's a bad voltage regulator.
Thanks in advance.
Ideas, thoughts, questions...
Old Jul 3, 2016 | 04:17 PM
z31freakify's Avatar
z31freakify
Check the pig tail with two wires on the alt. sometimes they don't make a good connection and give erratic readings and giving that nice little battery light.
Old Jul 3, 2016 | 05:01 PM
crop harvester's Avatar
crop harvester
It should be charging more close to 14 volts.
Old Jul 3, 2016 | 05:15 PM
cleatus12r's Avatar
cleatus12r
Butt-Head
The ONLY thing that can cause the battery light to illuminate on a 2001 is the voltage regulator or the ignition feed wire being shorted to ground. My guess is loose regulator mounting screws. They come loose pretty regularly.
Old Jul 3, 2016 | 05:34 PM
mecdac's Avatar
mecdac
Lightbulb
I'll check that today, thanks.
It usually charges at 13.9 - 14.2 after it's warm.
Thanks for that, will check.
fixnair
Nov 15, 2018 07:32 PM
Mustangman68
Jun 29, 2017 06:01 PM
2danglong
Mar 2, 2011 01:32 PM
bwells
Sep 27, 2010 12:37 PM
rosa70
Electrical Systems/Wiring
Aug 5, 2005 10:43 AM
