I got a complete dual alternator set up for free but I need to buy the ac manifold hose set to put it on does any one know the motorcraft part number ? I have been searching for it with no luck. Thanks in advance
The only difference with the hot side pipe is it has a flat depression where it passes the lower 2nd alternator. You can easily flatten or dimple a stock pipe to achieve the clearance.
I got the pipe but not the ac line and just looking at the two trucks mine is much different. The hose runs right where the 2nd alt mounts. My line is starting to seep oil so with it 105+ deg here in Cali that will be fixed before it stops working and if I replace it I want to put the hose on that will work with the dual alt set up so I can put it on if I ever get around to it
