86 ford van fuel injection
Old Jan 17, 2002 | 12:42 PM
Dan G's Avatar
Dan G
Hello. How you guys doing? I have a question for you. Do you think this set up will work with a 86 ford van fuel injection. The motor is a 1975 302 bored 30 over. It's got 9 to 1 compression. Has a summit cam with 262 intake duration and 272 eghaust duration adv. The lift on the intake is 448 and 472 on the eghaust. Summit shorty headers, a MSD blaster coil; a holley distributor module and an accel distributor cap. I'm going to use the stock y pipe into the front catalytic convertor, eliminate the second cat and put flowmaster 40 series delta flow and come out with 2 2 1/4 pipes out the back. And also should I use a k&n air filter or stick with a stock one. Thanks! Dan G
Old Jan 18, 2002 | 09:11 PM
madman666's Avatar
madman666
Sounds sweet!
I think you should be ok, are you going to run the stock computer?
You may need to get a chip for that setup.
Why don’t you post your question in the 80-86 trucks and vans, they may be able to help you out.
Old Jan 18, 2002 | 09:52 PM
madman666's Avatar
madman666
