Broken header bolts
Old Jun 29, 2016 | 10:45 PM
LJForrist's Avatar
LJForrist
Broken header bolts
Thought I would share my fun. My 72 f250 has a 360 in it that the previous owner had broken off two of the header bolts. The header was clamped to the head with these awesome clamps.
The exhaust leaks were pretty bad so I decided to tackle removing the rest of the bolts, removing the broken ones, and trying to get it sealed up.
Old Jun 29, 2016 | 10:49 PM
willowbilly3's Avatar
willowbilly3
the clamps do work. Ugly enough. On my last FE, I most of those top ones off trying to get them out. It's pretty hard to get in there with a comon drill so I used a torch and blowed through the old bolts and used grade 8 1/4" bolts with nuts and washers. You'll never have another siezed bolt again. And forget those gaskets because they just blow out again. Just clean everything up good and used a film of high heat silicon.
Old Jun 29, 2016 | 11:01 PM
LJForrist's Avatar
LJForrist
I had soaked the bolts down with pb a few times days before. Then in the morning I soaked it down and ran it to get the bolts warm and soaked them again. Let it sit for a few hours to cool down and soaked it one more time.
I got out my 3/8 impact and 3/8 wabbley socket and feathered each of them forward and backward until I got movement, then I threaded them right out all of them came out like this except one. I resoaked it, got a 3/8 breaker bar and felt it out both ways several times, no movement. Broke out the half inch impact and rattled it forward and backward a few times. Got it up to 4 power and it finally broke loose and threaded out.
Now to just get the broken bolts out.
Old Jun 29, 2016 | 11:06 PM
Ford_Six's Avatar
Ford_Six
I've done the clamp trick and the undersize bolt trick, both work well. If you're really good with a torch, you can clean all the bolt out without disturbing the threads, but that works better in blind holes.
Old Jun 29, 2016 | 11:12 PM
HIO Silver's Avatar
HIO Silver
Excising broken exhaust bolts is a rite of passage for FE owners... it's Ford's version of a circumcision!
Old Jun 29, 2016 | 11:20 PM
LJForrist's Avatar
LJForrist
I thought I was the only one hillbilly enough to use a torch. I tried a few thing until I burned up three drill bits in the drivers side front bolt. Got the torch. Blew through it till there was sparks on the back side. Tried running an easy out through it after that, no movement. I was then able to get a 5/16 drill through. Ran a 3/8 tap in it and it is good as new.
The passenger side rear, I cut the mount for the wheel well/fender and was able to drill it out from behind the right front tire. Drill punched through with a 1/8 first. Then 1/4, then 5/16. My hole was crooked so I chewed up my thread on one side. I got the tap to run through but it was pretty loose, so I thought I would just get a longer header bolt and nut the back side.
Old Jun 29, 2016 | 11:40 PM
LJForrist's Avatar
LJForrist
When do I get my bar mitzvah?
Old Jun 29, 2016 | 11:46 PM
LJForrist's Avatar
LJForrist
After getting everything apart, I was cleaning up the heads and the header flange. This is what the surface of the head looked like on the rear two exhaust ports on passenger side.
I figured that was gonna make it a little beyond what a gasket could do.
Old Jun 30, 2016 | 03:44 AM
GaryKip's Avatar
GaryKip
If you don't want to get them polished down at bit, then try the old J-B weld stuff. Let it cure at least 24 hours then sand it down. It won't be perfect. But it will be better than what you have now.
Old Jun 30, 2016 | 08:29 AM
Turbo Dog's Avatar
Turbo Dog
Good job working slow and steady to get that old rusty stuff apart. I would remove the head and have that surface machined...but I'm probably too picky on engine stuff.
Old Jun 30, 2016 | 09:22 AM
Talltruck's Avatar
Talltruck
Aaaahhhhh the fun of undoing the old hack jobs from generations of bad repairs. I still have a section of rust repair somebody made to my truck where they pop riveted a piece of aluminum over a rust hole and then smeared bondo over it all. Most of the bondo has long since fallen off but since they used aluminum none of that has rusted away, so I have a beautiful aluminum/rivet/bondo patch still hanging on to the bottom of a door.
Old Jun 30, 2016 | 09:50 AM
LJForrist's Avatar
LJForrist
That is hilarious. A few months ago when I was cutting out pat of my passenger floor pan to replace. My brother in WA was telling me about how he reap airs his floor pan with poprivets and silicone. Just covered in carpet. No one will be the wiser.
I am by no means a perfectionist. But my hack jobs only go so far
Old Jun 30, 2016 | 10:56 AM
willowbilly3
You did good. If you have time and patience you can work them loose. The few times I have addressed the issue it was on my daily driver and I didn't have the luxury of soaking them very long in PB, needed to get it fixed so I could get to work the next day. Those heads are a mess, never seen any pitted that bad.
Old Jun 30, 2016 | 12:29 PM
LJForrist's Avatar
LJForrist
Only two of the ports were that bad, the rest looked ok. I frosted the gaskets with high temp copper rtv on both sides and clamped in. I guess we will see how it goes.Name:  photo938.jpg
Size:  1.00 MBName:  photo726.jpg
Old Jun 30, 2016 | 01:58 PM
Turbo Dog's Avatar
Turbo Dog
Good idea, now only time will tell.
