Schematic for 1972 camper special
Old Jun 28, 2016 | 08:57 AM
Mgehley's Avatar
Mgehley
Does anyone have a link to a schematic of the 1971 Camper Special? I am a newbie and would like to see where things are according to factory specs. Specifically I am looking for fuel pump and any inline filters. Thank you!
Old Jun 28, 2016 | 09:33 AM
RichS2659's Avatar
RichS2659
Ah, grasshopper newbie, don't need no schematic. It is not electrical anyway. Besides, what model, F-100, 250, 350? Engine, 240,300, 302, 360, 390? Any who, point to front of carb. Follow fuel line down to left front driver's side of engine. The fuel pump is attached to the side of the engine. The fuel filter is in the twist off can mounted above or below the fuel pump depending on engine. Best to use a strap wrench to twist the can off to get to the cartridge filter. You can use channel locks , but be careful that you don't crush the can.
Old Jun 28, 2016 | 10:08 AM
Mgehley's Avatar
Mgehley
Thanks!
It's a 250; 360 according to the tag. Thank you so much! I'll retrace the lines today. Found the filter, now just need to locate the pump.
Old Jun 28, 2016 | 11:34 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by Mgehley
It's a F250; 360 2V according to the tag.
Originally the corrugated paper cartridge fuel filter was located inside a canister that threaded onto the fuel pump.
But, some people were unaware, so they installed in-line fuel filters instead.
C4AZ-9365-B .. Cartridge Fuel Filter (Motorcraft FG-1A) / Available from Ford & auto parts stores.
Applications: ALL 1964/76 Myriad FoMoCo Vehicles.
Old Jun 28, 2016 | 02:15 PM
Uni Moe's Avatar
Uni Moe
If you found the filter, you found the fuel pump.
Old Jun 28, 2016 | 03:42 PM
70FE250's Avatar
70FE250
The pump is connected to filter as Moe said, but in the future ifyou want to look at some schematics FORDification.com - The 1967-1972 Ford Pickup Resource is your best friend
Old Jun 28, 2016 | 03:45 PM
NumberDummy
1964/72 Ford Truck Parts Catalog available on a C/D from hipoparts.com
This is the same catalog that Fordification, FTE members are using.
riggerparish
Apr 3, 2013 03:22 PM
Philo Beddoe
Mar 8, 2013 11:32 AM
Argess
Sep 2, 2009 06:33 PM
bigwall
20
Dec 1, 2003 02:52 PM
eric in tn
Mar 31, 2003 07:54 PM
