steering hang spots
Old 06-26-2016, 12:17 PM
greyhound's Avatar
greyhound
greyhound is offline
Question steering hang spots
Have 1985 ford e150 van,with 351 motor with automatic and power steering.Driving it and turning right or left and has a hang spot,you can feel it when coming back to center point and some times just moving the steering wheel a little bit while driving.So I greased everything and still has a slight hang spot.So when the van is neutral and not running rock the steering wheel and have a inch of play.You can feel a little drag.Is it the top bearing in the gearbox going bad,none of the ties rods are moving at that point.Guess the point is it power steering pump or gear box.Hate too see it lock up when driving.All the people I could ask are dead and the rest are bowtie boys.Thanks for your support.Greyhound
Old 06-27-2016, 12:49 AM
jimandnena's Avatar
jimandnena
jimandnena is offline
Hi greyhound,
here is the discussion on setting/checking steering boxes. Your issue is serious if it is something in the box that is broken. jim
https://www.ford-trucks.com/forums/1...one-right.html
Old 06-27-2016, 02:13 AM
annaleigh's Avatar
annaleigh
annaleigh is offline
Have you checked the flex coupling that connects the steering shaft to the gearbox? You also have bearings in the steering column itself.
Old 06-28-2016, 02:34 PM
greyhound's Avatar
greyhound
Question
Hello,
Thanks,thats the first thing I checked.Then that floored me to look for another problem.Will search some more.Thanks
Old 06-28-2016, 04:02 PM
annaleigh's Avatar
annaleigh
If you have a tilt steering wheel, you also have a u-joint in there.. I don't know if they ever go bad. I would think having the steering column straight and turning the steering wheel would check that out though..
Just making suggestions before you have to go in to the gear box...
<a href="http://s472.photobucket.com/user/Annaleigh_123/media/85steering2.jpg.html" target="_blank"><img src="http://i472.photobucket.com/albums/rr88/Annaleigh_123/85steering2.jpg" border="0" alt=" photo 85steering2.jpg"/></a>
Old 06-28-2016, 06:02 PM
greyhound's Avatar
greyhound
Smile diagram
Thanks, I can now get the picture here.Makes more sense now.Having all ford cars and trucks since 1966,never had a problem like this before.Will check out the parts stores and rockauto to see whats around to fix this.Thanks Again greyhound
derek0525
24
06-25-2016 07:22 PM
bladez51
20
06-25-2011 07:26 PM
devongarver
1999 to 2016 Super Duty
10-30-2010 11:43 PM
kwemj 67
09-02-2010 10:26 PM
Mustangfreak
05-13-2009 08:01 AM
Quick Reply: steering hang spots
