Need Help identifying these wheels
I don't recognize the two wheels in the lower pic.
1977 was the first year that F100/150's were available with styled aluminum & styled steel wheels, Bronco's got the same types in 1978.
The hubcaps (Ford called them ornaments) attached to the wheels with (3) steel or nylon anchors and (3) chrome or black screws.
The holes for these parts were within the bolt circle pattern.
US Wheel Online ? Truck / 4x4
The lower pic has "slot mags" that everyone used to produce. The Ansen Sprint was the premier slot mag in the day. Cragars would be good too. But I'm pretty sure you will find the Ansen or Cragar name cast into the back of the wheel, as those were top line wheels, not generic wheels cast in Japan or Taiwan and labeled with a sticker.
You can check ebay for values, and you can probably sell them fairly easily for a bit more than the price of scrap aluminum.
Check the back sides carefully, and check the bolt pattern as well. 5 on 5.5" is what you are looking for to fit Ford pickups and vans.
You might have better luck selling them without the tires. Hard to say. No one in their right mind would run those tires any distance, but there are plenty who would--be sure to get CASH.
The aluminum slot wheels look to be 15x8.5, one way to determine what brand they might be is what lug nuts the wheels need to be bolted on correctly. Both sets of wheels need a shank & washer lug nut. What makes the difference is how long of a shank is needed on the lug nut without bottoming out against the brake hub before the lug nut & washer is tight against the wheel. Cragar wheels typically use a longer shank lug nut, Ansen, Western, and Cal Custom, they could use short or long shank lug nuts.
My totally unscientific wild guess is the aluminum slot wheels are Ansen brand from the late 60's to the early 70's. By the mid 70's most aftermarket wheel manufacturers had quality control processes in place to make sure they all matched. The aluminum slot on the left has the lug holes correctly aligned with the spokes. The one on the right, the bolt pattern is drilled kind of near the center of the slots/big holes, a common thing on early Ansen wheels.
Even though the tires are extremely old, I wouldn't be surprised if some retro hot rodder would be interested in buying them for show car duty. Try to drive with those tires and you're looking at 4 blowouts by the end of the block, but if they are crack free on the sidewalls and hold air, someone may want them.
