1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
How to quickly inflate tires to 80psi?
Old 06-28-2016, 11:31 PM
truckfella's Avatar
truckfella
truckfella is offline
Interesting! Close-up's of the tire fittings please? And/Or part numbers?
Old 06-30-2016, 11:48 AM
droldsmorland's Avatar
droldsmorland
droldsmorland is offline
Most tire shops will take out the schrader as part of the tire install process. Inflate above the rated sidewall psi then let air out as they install the schrader.
Old 06-30-2016, 01:20 PM
Super Duty DJ's Avatar
Super Duty DJ
Super Duty DJ is online now
Originally Posted by truckfella
I have a compressor in my garage with a 22 gallon tank which is kept between 130-150psi, and a standard (fairly high quality) 1/4" rubber hose.
You state that your compressor tank is kept between 135-150 psi, which is pretty typical. Almost all compressors also have a pressure regulator that sets the pressure into the hose. If you set your regulator to 80 psi, it will take much longer to inflate your tires than if you set the regulator to a higher pressure, like 100-120 psi. As others have stated, upgrading to a larger diameter hose will dramatically increase your airflow. Going to a 3/8" hose instead of the 1/4" hose will likely come close to doubling your air flow rate. Your compressor is plenty large enough to keep up with inflating your tires and really shouldn't be the limiting factor in this situation.
Old 07-01-2016, 06:28 AM
ruschejj's Avatar
ruschejj
ruschejj is offline
You might burn up the motor on your current compressor but if I were you I would add aux. air tanks to your compressor. Go buy 2 of those portable air tanks, connect them to your existing compressor so you have 3 reservoir tanks, this triples your available air.
Most buds of mine just use the tank from an old hot water heater but could be unsafe if you don't know what to watch for.
Old 07-02-2016, 09:16 AM
POS Camaro's Avatar
POS Camaro
POS Camaro is offline
Another thing to think about is that the quicker you fill the tires, the hotter the air in the tire from compressing the air already in there. PV=nrT As it cools off, the tire pressure will lower and you should check and refill a second time. Slow and steady will actually win this race.
jdadamsjr
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
11-26-2014 04:17 PM
Technologiq
04-25-2013 08:12 PM
2006FordTruck
01-01-2013 07:24 PM
Ranger1F150
03-21-2008 06:06 PM
56jimmyno1
03-30-2007 10:34 AM
Quick Reply: How to quickly inflate tires to 80psi?
