Portable air
Old Mar 20, 2008 | 02:06 PM
Ranger1F150's Avatar
Ranger1F150
Portable air
Is there a portable air compressor that is better for truck tires ? I have tried a couple different portable 12 volt compressors none of them do that great of a job getting these big tires up to 50 PSI. It seems like they struggle and take forever. I tow a good size camper and am looking for something I can leave in the truck to fill up the truck and camper tires from time to time.
Old Mar 20, 2008 | 03:18 PM
hofuf's Avatar
hofuf
I bought one at a truck stop. Provides higher volume of air.
Old Mar 20, 2008 | 11:36 PM
AK-Excursion's Avatar
AK-Excursion
You can get one of the on board tanks mounted, 1 to 5 gallon, under the cab. nice thing about the set up is you can also hook up air horns to them as well as a compressor hose for filling tires or whatever its needed for. If you get air suspension you will already have the tank for that also. So it very versatile.
Old Mar 21, 2008 | 06:57 AM
Ranger1F150
What does that cost or where can get one ?
Old Mar 21, 2008 | 06:06 PM
AK-Excursion
Here is the kit that includes the air horns, I know you can get the tank and compressor separate I just cant find where I seen the separate kits. This kit includes the 50' hose for toping tires like you said, might not need that much hose for a truck.
This is the expensive perminante way but adds alot of options and is worth it if you plan on towing and adding air suspension later on.
http://www.campingworld.com/browse/s...=3917&src=SRQB
