D3VE head milling
Old Aug 17, 2003 | 08:51 AM
stuperscout's Avatar
stuperscout
Question D3VE head milling
Does anyone know how much I can machine off of D3VE heads before I have any fittment problems (intake and/or valve clearance) pistons are +040 smog (big dish) the cam will be comp extreme 4X4 270/278 advirtised 226/234 @ .050 .554/.574 lift I'm trying to stick with these heads for now due to budget issues. Mill work for me is cheap/free. what would the net compression be? its about 8.0:1 now
Old Aug 17, 2003 | 12:16 PM
georgedavila's Avatar
georgedavila
D3VE head milling
Amount of stock to remove to assure correct mating of ports;
----------------------------------------------Remove from Intake
Engine-----Removed from head/block----------Sides-------Bottom
429-460----------.010------------------------.010--------.014
------------------.020------------------------.020--------.028
------------------.030------------------------.030--------.042
------------------.040------------------------.040--------.057
Old Aug 17, 2003 | 01:09 PM
stuperscout
D3VE head milling
If I remove .040 from head face(block/cylinder side)what do you mean by the sides and bottom?
Old Aug 17, 2003 | 02:43 PM
georgedavila
D3VE head milling
Of the intake manifold.
Old Aug 17, 2003 | 06:10 PM
stuperscout
D3VE head milling
is .040 the limit and if so do you know the resulting compression
how far untill a valve interferance? do you foresee any valve problems?
Old Aug 17, 2003 | 07:16 PM
georgedavila
D3VE head milling
I don't see any problem with valve clearance, but it's always a good idea to mock it up for insurance.
You need all the data on your engine, including deck height, to determine C/R.
38 coupe
13
Feb 4, 2017 02:55 PM
Boots on ground
15
Jan 18, 2017 02:42 PM
38 coupe
1947 and Older Ford Trucks
26
Mar 10, 2016 07:16 PM
carlmaass
Jul 20, 2011 03:05 PM
390freak
Jul 13, 2003 07:29 AM
