Sponsored by: Real Truck
Improving Ride Quality
Old Jun 24, 2016 | 01:24 PM
  #31
gpops's Avatar
gpops
Originally Posted by ak-angler
Whether or not a person would 'get caught' is irrelevant regarding the statement that installing tires having a lesser load rating is illegal. If it is actually illegal to do so, it should be a pretty easy task to provide some documentation of that. That's what I'm looking for.
Found this information online:
https://www.fmcsa.dot.gov/regulation...section/393.75
(f) Tire loading restrictions (except on manufactured homes). No motor vehicle (except manufactured homes, which are governed by paragraph (g) of this section) shall be operated with tires that carry a weight greater than that marked on the sidewall of the tire or, in the absence of such a marking, a weight greater than that specified for the tires in any of the publications of any of the organizations listed in Federal Motor Vehicle Safety Standard No. 119 (49 CFR 571.119, S5.1(b)) unless:
(1) The vehicle is being operated under the terms of a special permit issued by the State; and
(2) The vehicle is being operated at a reduced speed to compensate for the tire loading in excess of the manufacturer's rated capacity for the tire. In no case shall the speed exceed 80 km/hr (50 mph).
Old Jun 24, 2016 | 01:29 PM
  #32
ak-angler's Avatar
ak-angler
Originally Posted by gpops
That doesn't say that it's illegal to install lower weight rated tires. In fact, it seems to allow doing so, specifically stating that the load rating on the tire can't be exceeded (with some notable exceptions).
Old Jun 24, 2016 | 01:33 PM
  #33
ak-angler's Avatar
ak-angler
Further... that link (and the quoted information) is only applicable to commercial motor carriers. It doesn't effect private motor vehicles.
Old Jun 24, 2016 | 02:04 PM
  #34
gpops's Avatar
gpops
I agree and did not notice the link was for commercial vehicles. All this lawyer talk makes my brain rattle.. especially on a Friday afternoon ready to leave work!!
Found more documentation for all vehicles under the National Traffic and Motor Vehicle Safety Act:
eCFR ? Code of Federal Regulations
S5.1.2 Except in the case of a vehicle which has a speed attainable in 3.2 kilometers of 80 kilometers per hour or less, the sum of the maximum load ratings of the tires fitted to an axle shall be not less than the gross axle weight rating (GAWR) of the axle system as specified on the vehicle's certification label required by 49 CFR part 567. Except in the case of a vehicle which has a speed attainable in 2 miles of 50 mph or less, the sum of the maximum load ratings of the tires fitted to an axle shall be not less than the gross axle weight rating (GAWR) of the axle system as specified on the vehicle's certification label required by 49 CFR part 567. If the certification label shows more than one GAWR for the axle system, the sum shall be not less than the GAWR corresponding to the size designation of the tires fitted to the axle. If the size designation of the tires fitted to the axle does not appear on the certification label, the sum shall be not less than the lowest GAWR appearing on the label. When a passenger car tire is installed on a multipurpose passenger vehicle, truck, bus, or trailer, the tire's load rating shall be reduced by dividing by 1.10 before calculating the sum (i.e., the sum of the load ratings of the tires on each axle, when the tires' load carrying capacity at the recommended tire cold inflation pressure is reduced by dividing by 1.10, must be appropriate for the GAWR).
This is saying unless your vehicle can only reach a speed of 50 mph (80 kmh), the tires have to be rated to at least the axle's gross weight rating (GAWR).
Old Jun 24, 2016 | 03:00 PM
  #35
ak-angler's Avatar
ak-angler
Found more documentation for all vehicles ...
Not exactly... It's for vehicles over 10k gvwr (and RV trailers). But, I'll concede that it may apply to some Superduty's.
That's true. The total weight capacity of the tires on an axle (for vehicles over 10k gvwr) must be higher than the load rating of that axle. Still doesn't say it's illegal to install tires with lower weight rating. Am I splitting hairs? Maybe.
Last edited by ak-angler; Jun 24, 2016 at 03:58 PM. Reason: Clarification of poorly written sentence.
Old Jun 27, 2016 | 08:10 AM
  #36
JimRay's Avatar
JimRay
Hey guys, does your truck rear seem to jump right if you hit a bump? Mine does with the FX4 package.
Old Jun 27, 2016 | 12:46 PM
  #37
gpops's Avatar
gpops
Did some searching online and found that's normal with a light rear end and solid axle. A few people said that changing their shocks solved it, but I think the consensus is to drive slower over bumps
truck jumpd sideways over bumps? [Archive] - Dakota Durango Forum
Old Jun 27, 2016 | 12:59 PM
  #38
wizkid00104's Avatar
wizkid00104
I believe they jump more if the shocks have a very stiff compression stroke. It is also a characteristic of stock leaf springs because their spring rate is so high and a light rear end.
Old Jun 27, 2016 | 01:29 PM
  #39
kcducttaper's Avatar
kcducttaper
I don't know if this is particularly true or not, but it seems that trucks with an open diff mostly just bounce more up and down over bumps in the rear where trucks with an LSD in the back bounce around sideways a lot more over the same bumps. Seems like all of the LSD trucks I've driven have been much more squirrely on the same washboards and dirt roads than similar pickups with an open diff.
Case in point: Your FX4 has an LSD (I presume) and bounces to the right. My dad's Silverado Z71 has and LSD and bounces...not sure which direction, but it definitely bounced sideways in the rear and was pretty bad on the stock tires. A tire change did help, but on bad washboards, it definitely still goes sideways - sometimes enough to make the traction control perk up a bit. My open diff F-250 has never once bounced sideways back there. Now, sometimes it'll buck you up out of your seat like a bronco, but it never goes sideways. That's one of my primary reasons I'm thinking to go selectable locker instead of dropping in an LSD. LSD's just seem to bounce funny. Again - not sure if that's a law of the universe or anything - just something I've noticed in my experience.
Old Jun 27, 2016 | 02:29 PM
  #40
JimRay's Avatar
JimRay
Yes, I have a locker and thought that maybe the right side step could be because of the staggered shocks???
Old Jun 29, 2016 | 01:15 PM
  #41
stufarmer's Avatar
stufarmer
Let me re-phrase may comment about the legality of replacing your tires with tires with a lesser rating that originally required by the manufacture.
If..by any chance you are carrying/towing at your vehicle's original GVW rating and..you are involved in any incident where your cargo was a factor in any manor and .. if an accident investigator finds your vehicle not to be in compliance with the manufactures minimum tire rating it CAN become a citable and an at fault offense.
And .. it scares me to think anyone would be STUPID enough to challenge the legality of such
Old Jun 29, 2016 | 03:41 PM
  #42
FordBlueHeart's Avatar
FordBlueHeart
Just like it's a citable and at - fault offense for having a properly equipped truck and towing more than the gross combined weight rating. Or speeding. Or passing on the right on the shoulder or...
crazyrwe
Jul 21, 2011 08:15 AM
gdsqdcr
1997 - 2003 F150
Apr 27, 2006 10:38 AM
tripleup05
Dec 7, 2005 10:46 AM
uofmtigers
Aug 28, 2003 12:56 PM
924x2150
Dec 16, 2002 01:13 PM
