Ac probs
Old Jun 21, 2016 | 07:28 PM
Alex78's Avatar
Alex78
Ac probs
I have a 2005 f150 4 Dr. My fan sounds like it's going to come thru my glove box. I replaced the blower resistor and that did not work. I have cold air blowing out, it just gurgles real bad. And it's hot out. Any suggestions
Old Jun 21, 2016 | 07:59 PM
projectSHO89's Avatar
projectSHO89
None of that makes any sense. Try again. Pretend you're explaining it to a mechanic, not someone on facebook.
Old Jun 21, 2016 | 08:08 PM
Alex78's Avatar
Alex78
When I turn my fan on, it sounds like it's going to come thru my glove box
Old Jun 21, 2016 | 09:15 PM
steve(ill)'s Avatar
steve(ill)
It is possible for the fan motor bearings to dry out or fail.. then the fan rattles or grinds while spinning.. You could also have a mouse nest in the duct and rubbing on the fan blade cage. Only way to tell is to pull the motor / fan and test on the bench.. with the fan out, stick your hand inside the duct and feel for debris.
Old Jun 21, 2016 | 09:17 PM
Alex78's Avatar
Alex78
Copy. Thanks
Old Jun 21, 2016 | 09:32 PM
Ted928's Avatar
Ted928
I looked for a clapping emoticon but could not find it; this will do.
r2000f150
1997 - 2003 F150
Aug 12, 2015 12:41 PM
RDC F250 7.3
Jul 16, 2008 12:56 PM
lostaggie78
Jan 19, 2005 10:03 PM
Lakeitel
Jun 12, 2002 09:24 PM
