possible fuel pump problem has 2 pumps..
Old 06-26-2016, 10:36 PM
annaleigh's Avatar
annaleigh
annaleigh is offline
Well I replaced the filter and pump in the tank with a Delphi. Delphi seemed to have the highest ratings of anything available in this area. NAPA had Airtex and the other options were precision and car-quest. I couldn't see anything wrong with the PO's instillatio. It was a precision pump/sending unit combo.
The Delphi kit had a much thicker rubber hose connector that was very tight to get on. i hope it wont be a problem but I didn't like the plastic hose clamps and used standard screw type clamps on the rummer connector. I dont think it will ever suck any air now!
I don't think the tank had filled up all the way the last time I filled it. perhaps because the pump I filled at has a sloping concrete pad where you park making the front of the van a bit higher then the back. I checked the filler neck vent pipe and it was not clogged. But my guess is that the tank had ran dry.
I had planned on measuring the total amount of gas we removed but I had a neighbor helping and my time was limited. We siphoned most of the gas into the new tank for my 85 e150 then used coking oil containers I had picked up from the back of a restaurant, they work great but were only 2.5 gallons each. Being in a hurry, we just sat the 85 tank up on top of a trashcan and siphoned the gas from that tank back into the van.
Though not exactly proper service procedure, I bent the arm on the sending unit upwards a little hoping it would now when the dash gauge registers empty, it wont be empty! WE had put 4 gallons back in the tank and I checked the dash gauge, it was still registering empty. After filling it up, it went way past the full mark like before..
Thanks for all the help and suggestions
Anna
Boss351Bronco88
1978 - 1996 Big Bronco
11-29-2011 11:50 AM
kennyrandolph
03-13-2009 04:24 PM
weswes01
10-28-2007 05:34 PM
anmlcrkr
10-10-2004 07:12 PM
Todd F250
29
12-24-2002 01:45 PM
Quick Reply: possible fuel pump problem has 2 pumps..
