Distribrutor brands...
Old Aug 17, 2003 | 12:43 AM
Rick X's Avatar
Rick X
Hi all,
'78 F100, 400/C6, 2WD...rebuilt engine and when switching from points to electronic ignition put in a rebuilt 'stock' distributor. The thing leaks oil where it sets in the block and I figure I either nicked the upper o-ring or it's a loose fit.... Anyway, I'm looking to go and put an aftermarket distributor in and wanted to know the consensus of the experienced folks here...which brands work best with Ford trucks and what mods are necessary for those certain brands...e.g. new ignition module, coil, etc.? Of course, cost is always a factor!
Some brands I've looked at are; MSD, Accel, Mallory, and Proform....
Thanks,
Rick
Old Aug 17, 2003 | 07:50 AM
71swissaqua's Avatar
71swissaqua
I went MSD all the way and love it. Advance curves are easy to plat with and no spark scatter. I had a rebuilt Duraspark in there to begin with and my timing marks jumped around a good bit. With the MSD they are steady.
Clint
Old Aug 17, 2003 | 08:15 AM
Torque1st's Avatar
Torque1st
Posting Legend
On some distributors and particularly the reman units the powdered metal "cam" is damaged with nicks and burrs. Clean those up with a fine file and it will help make your spark timing steady.
There are a number of threads on ignition systems here as well as in the engine forums. Use the search function to find them.
I use the stock units and blueprint them. I use MOTORCRAFT ignition modules which usually work better than aftermarket up to around 5500 rpm. If you have a racing application where you operate in the 5000+ rpm range most of the time then aftermarket MSD units are probably best. I use the stock units because testing service and replacements are available at parts stores.
Mount a MotorCraft ignition module with 1/4" spacers under it to allow room for cooling air under it.
Old Aug 17, 2003 | 08:17 AM
laptopgeek's Avatar
laptopgeek
Rick X ~
When I built my 460 I changed it over to a Mallory induction unit - no points - it's been great for 1 1/2 years.....cranks every time...
Old Aug 17, 2003 | 02:22 PM
proeliator's Avatar
proeliator
I've used almost them all, and now, I would use nothing but a Davies Unified Ignition. They custom curve them just for your application and the dizzy and HEI is all one piece. One wire hook up. Seems like guys have either bad luck or good luck with the MSDs. Have had my share of both. Can't recomend the DUI strongly enough.
Old Aug 17, 2003 | 05:31 PM
Torque1st's Avatar
Torque1st
Posting Legend
The good thing about the DUI is that it uses std off the shelf GM HEI components. The GM HEI is solid "like a rock" -hehe!
There are only two bad things about the DUI setup. One is that you loose the approx 20 degree ignition retard function for easier starts that you have with the std Ford OEM systems. While that function is great under some conditions it is not always needed. The other thing is the $$$
Old Aug 17, 2003 | 10:23 PM
proeliator's Avatar
proeliator
HEI is one of the few things brand x ever had over Ford in my book. The DUI set up uses their own components that run hotter and are a bit better than standard fare, but can indeed be replaced by run of the mill chevy hei parts and run without a hitch. A big plus, aside from the shame of having chevy parts on your Ford It is $$$ but I've got enough grey hairs from tracking down electrical gremlins and testing and re-testing various electric ignition components to make it worth it.
Old Aug 18, 2003 | 04:29 AM
Torque1st's Avatar
Torque1st
Posting Legend
I know what you mean about the gray hairs, -I have progressed beyond that over the years to no hair!
I have no shame about putting "foreign" parts on my Ford when I feel they do a better job or fit better. I have a Mopar air box and I am putting a GMC front end under my truck...
Old Aug 18, 2003 | 06:02 PM
gsg1981's Avatar
gsg1981
I've got a good friend with a DUI setup on his 400 and he loves it. It certainly outperforms the standard setup on my 400.
As for the GM front end... Care to elaborate?
Old Aug 18, 2003 | 10:31 PM
Torque1st's Avatar
Torque1st
Posting Legend
It's a complicated process I wouldn't recommend it for fun. I just hate Twin Idiot Beams.
Old Aug 19, 2003 | 06:46 AM
jalampi's Avatar
jalampi
MSD is working great for me.
Old Aug 19, 2003 | 06:52 AM
LxMan1's Avatar
LxMan1
Mallory Unilite is the best out there. It's modern technology compared to the 20 year old magnetic pick-up design that's used in the other M brand. No timing fluctuation even if the shaft gets a little play in the bushings.
Jimmy
Old Aug 19, 2003 | 11:38 AM
proeliator's Avatar
proeliator
I thought the Unilites used optic sensors....
I've known quite a few guys who comlained about them because any dust or grit could throw off the sensor.
Old Aug 19, 2003 | 10:42 PM
Torque1st's Avatar
Torque1st
Posting Legend
Gee, I thought everybody had abandoned the use of opticals because of the dust problem.
Old Aug 19, 2003 | 11:42 PM
proeliator's Avatar
proeliator
That sounds oddly like sarcasm...? The optics have just been known to be overly sensitive and problematic.
