Wet spot
Old Jun 19, 2016 | 11:21 AM
Gooz's Avatar
Gooz
Wet spot
I have a 92 Ford F-250 Custom extended cab and Every time it rains, I wash the truck, or even take it to the car wash there is always a wet spot on the driver side floor board and I just can seem to find where it's coming from. If anyone can help it would be greatly appreciated.
Old Jun 19, 2016 | 11:22 AM
Festus Hagen's Avatar
Festus Hagen
Methanoholic
Upper left windshield corner ...
-Enjoy
fh : )_~
Old Jun 19, 2016 | 12:03 PM
Gooz's Avatar
Gooz
-Enjoy
fh : )_~
You think it needs to be re done or the chrome trimming needs to be re done as well?
Old Jun 19, 2016 | 12:15 PM
Festus Hagen
Methanoholic
The trim does nothing but look pretty (hides the edge of the glass).
These windshields are set in urethane and have to be cut out and replaced unless they get lucky and get it out without breaking it ... On the flip side they are only about $200 installed.
To verify that is where the water is leaking, use a garden hose and run water around the top of your windshield, it is easier with two people, one on the hose and one inside looking for water leaks ...
Also check your door seals and door windows while you are at it ...
-Enjoy
fh : )_~
Old Jun 19, 2016 | 12:18 PM
Gooz's Avatar
Gooz
-Enjoy
fh : )_~
I hope they can remove it without cutting it out. I wanted to stay completely stock with all the windows having the VIN on them. Thank you for the help I really appreciate it!!
Old Jun 19, 2016 | 12:34 PM
Festus Hagen
Methanoholic
There is no VIN on glass ...
They are impossible to remove without cutting them out, they are set in urethane, meaning they are glued in!
To remove, the urethane has to be cut and typically the windshield is broke doing so ... Or at least the edges get chipped thus ruining the glass.
But don't jump to conclusions until you water test to find the leak, it could be a door window or seal leak!
-Enjoy
fh : )_~
Old Jun 19, 2016 | 02:06 PM
Gooz's Avatar
Gooz
-Enjoy
fh : )_~
All my windows including rear and front windshields have VIN number engraved on them. The only ones that don't are the small windows on the door.
Old Jun 19, 2016 | 02:41 PM
Festus Hagen
Methanoholic
Who did that and why ...
-Enjoy
fh : )_~
Old Jun 19, 2016 | 02:45 PM
Gooz's Avatar
Gooz
I'm pretty sure the old guy that I bought it from bought it like that brand new! And it's just been siting in a barn most of the time. And got rid of it because didn't want it sitting anymore.
Old Jun 19, 2016 | 03:12 PM
Festus Hagen
Methanoholic
It's not something done factory.
It was likely done as a theft deterrent by the PO. Useless for the most part! Chop shops could care less about glass ...
Thus it's as simple as having the new one engraved ... As you would have no choice if it's leaking, unless of course they were able to get it out without breaking it, Possible, but unlikely by a glass shop, they just wouldn't care!
I guess you could silly cone it ... The ultimate oxymoron!
-Enjoy
fh : )_~
Old Jun 19, 2016 | 04:12 PM
Gooz's Avatar
Gooz
Well I feel like a retard lol over here thinking my truck was special. I thought I was so kool too haha
Old Jun 19, 2016 | 05:20 PM
Festus Hagen
Methanoholic
92 Ford F-250 Custom extended cab ... Is proof you are not a retard!
-Enjoy
fh : )_~
Old Jun 20, 2016 | 08:05 AM
Scndsin's Avatar
Scndsin
Doesn't hurt to clean out the inside of the cowl but might be a challenge for you mechanically to take off & re-install. Trash builds up in there creating a dam that doesn't allow the water to drain easily. Lots of crap builds up behind the fenders too. The seam sealer dries out & shrinks creating pathways inside as well.
brc777
1997 - 2003 F150
Mar 10, 2018 04:16 AM
hillcountryflt
Sep 7, 2014 02:33 PM
cadunkle
Dec 23, 2013 08:21 AM
Rudy Strickland
Mar 8, 2013 06:22 PM
4inchlovin
24
Sep 16, 2008 06:05 PM
