running wide open when starting
Old Jun 19, 2016 | 08:15 AM
louda's Avatar
louda
I did some work on my valves when i put it back together it wants to run wide open the throttle is fine what could this be
Old Jun 19, 2016 | 08:39 AM
bashby's Avatar
bashby
What are you working on?
What work did you do to the valvez?
Old Jun 19, 2016 | 08:46 AM
louda's Avatar
louda
Got a ticking in the motor was just checking valves it still ran but when i got it back together it wants to run totally wide open
Old Jun 19, 2016 | 09:04 AM
bashby's Avatar
bashby
Year? Engine? Carb/efi?
Old Jun 19, 2016 | 09:25 AM
louda's Avatar
louda
Efi 1994 st six 300
Old Jun 19, 2016 | 01:54 PM
bashby's Avatar
bashby
Did you verify the throttle blades are completely closed? Maybe a big vacuum line unhooked letting air in? (PVC or booster) if you unplug the iac valve it should close and idle speed should be very low if it will idle at all.
louda
Jun 19, 2016 04:20 PM
Matthew Wilson
13
Jan 5, 2016 12:07 PM
Tommky
Apr 29, 2013 09:02 PM
SquareWheels
15
Feb 12, 2011 02:46 PM
chinook507
Modular V10 (6.8l)
Jan 24, 2011 06:25 PM
