Hi. I have a 94 E150 5.0L van with a 72 KOEO code. My Chilton's book says a 72 code could be the MAP sensor. I can't find one. I do have the MAF sensor after the air filter. Does this van have both sensors? If so, where is the MAP?
Seems like it should be simple, but Chilton is not clear and I don't have the Ford docs.
Thanks for the note. I have seen both 2 digit and 3 digit codes on this van. For instance, if I don't hit the overdrive button during the dynamic test, I get a 3 digit code. I am pretty sure the 72 is real. I have pulled the codes a few times already.
