1996 F150 axle code
Old Aug 16, 2003 | 10:29 PM
garyd's Avatar
garyd
1996 F150 axle code
I'm looking at a 1996 F150 302 automatic . Does anyone know if I can get the axle code from the VIN?? What axle ratios were available???? I forgot to check when I looked at the truck. It's an Eddie Bauer with 64,000 miles and looks and drives great.
I want to pull a 3500 pound camper.
Old Aug 16, 2003 | 11:29 PM
GypsyR's Avatar
GypsyR
1996 F150 axle code
No indication in the VIN, but there is code on the door "data plate". However I don't know anyone outside the dealership that can decode that. I'm sure people can though.
Easiest to get under the rear bumper and see what it says on the tag, 3.08 or 3.55, whatever.
Might not be easy to convince the seller to stick his head under there for you if you can't do it yourself though.
Old Aug 17, 2003 | 12:54 AM
ecarter50's Avatar
ecarter50
1996 F150 axle code
Old Aug 17, 2003 | 01:06 AM
acerockola77's Avatar
acerockola77
1996 F150 axle code
I would probably go with the 300 or the 351 over the 302 if you are hauling..
You can find the code for the rear diff in the door jam.
fl1a
Nov 25, 2015 07:23 PM
FSSF
Dec 7, 2014 05:45 PM
Spytnblud
Aug 18, 2014 06:38 PM
Brocrock
17
Aug 11, 2014 03:27 PM
BluecreekGT
13
Mar 8, 2014 11:51 AM
