V10
Old Jun 21, 2016 | 10:51 AM
  #31
RainDesert's Avatar
RainDesert
Originally Posted by Larietpsd
That's the one thing I'm worried about when my lease is up. Like the new superduty but just don't want the diesel. Afraid gas may be to weak . Maybe I will just go with another Eco
Coming out of 20yrs of diesel, into a 2015 ecoboost i was pleasently surprised at the power it had towing. I then went to my current 6.2. At first i had the same somewhat disappointed opinion too. But 10k miles later and having towed a bunch of different stuff i have come to really like the 6.2. It is not easy going from powertstroke to the 6.2 because i got so used to the low end turbo power. I dont have to buy another 6.2 but i want to. The 4.30 gears alone will make a big difference for the 6.2.
Old Jun 21, 2016 | 11:04 AM
  #32
fordmantpw's Avatar
fordmantpw
Originally Posted by troverman
I think, now that we have a 2.7L EcoBoost F-150 in the family, that the GDI twin turbo gas engine can perform every bit as well as a full-fledged diesel. I think a 4.5L V8 EcoBoost would be a monster producing an easy 500HP and 700lb-ft.
The two areas where the diesel would still always win out are actual fuel economy and longevity. Fuel economy is simply a result of required boost, and the diesels don't need as much boost as often as the gas turbos. When they do, however, they suck down the fuel just as well. The diesel engines also tend to have engine components designed to run for a longer lifespan. There won't be a timing chain stretch or guide issue on an HD diesel. No DI fuel pump wearing down a cam lobe. Tougher cranks and generally tougher blocks, although the 27L is a partial CGI as well. However, I think a lot of people could be well served by an EcoBoost engine in the Super Duty. Honestly, the high-output Raptor V6 would be a pretty interesting Super Duty engine.
Agreed. I tow about 9-10k lbs, but most of my driving is around town unloaded. I like the diesel for longer towing trips, and we plan to go out west in a few years, so I'm leery of the 6.2L going through the mountains. An EcoBoost would be great for my needs. I wouldn't expect an EcoBoost to get much worse fuel economy than the 8.5-9 MPG that I get towing with my 6.4L.
The Raptor version of the 3.5L would definitely be interesting in the F250.
Originally Posted by G8tr
The 3.5 is rated at 365/420. Going to a F250 gas just doesn't seem logical for my use. IF I were to go F250 it would have to be diesel to warrant the F250 IMO.
I pulled a 12k trailer full of rough sawn heart pine beams and the truck did fine. It wasn't a real long trip, probably 200 miles. Not sure what the new engines will do but hopefully the gas will go up with power.
The '17 3.5L EB is an all new engine, with preliminary numbers of 365/450. Mike Levine (Ford trucks marketing manager) has stated that the torque numbers WILL be higher once official specs are released (similar to the way the Fusion's 2.7L went from 350 to 380) so I would expect around 475 or 480. I also expect near 400 HP as well. That's pretty potent for a half-ton truck, so you would definitely have to need the heavier duty components of the Super Duty to make the switch if you didn't go diesel.
Old Jun 21, 2016 | 11:14 AM
  #33
troverman's Avatar
troverman
It initially doesn't seem "fair" that the half-ton pickup seemingly gets a more potent engine than the gas Super Duty. But you have to consider a few things - the Super Duty is sure moving a lot more mass than the EcoBoost, and that power is routed through a much heavier duty transmission which saps a bit more power than the lighter duty F-150 transmission. Placing the 3.5L EcoBoost in the Super Duty mated to the 6R140 would surely not result in as potent a vehicle as the EB F-150 is. The point of the Super Duty is towing and hauling and generally everyday use of capability. The much heavier duty transmission and understressed V8 help it to last a long time even with daily hard use.
I, too, came to appreciate the 6.2L. The 4.30 gears will help considerably as will the power bump and potential throttle recalibration. I think it is a great engine choice for the Super Duty if you want headache free operation and cheap maintenance.
Old Jun 21, 2016 | 01:34 PM
  #34
G8tr's Avatar
G8tr
So you feel very string my about repairs being cheaper on 6.2 than the diesel?
Old Jun 21, 2016 | 06:57 PM
  #35
troverman's Avatar
troverman
String? Not sure what you mean.
Old Jun 21, 2016 | 07:10 PM
  #36
Larietpsd's Avatar
Larietpsd
I also have to keep reminding myself that I tow heavy about 6-7 times a year.
Old Jun 21, 2016 | 07:24 PM
  #37
G8tr's Avatar
G8tr
Autocorrect - meant feel strongly
Old Jun 21, 2016 | 07:28 PM
  #38
Larietpsd's Avatar
Larietpsd
I loved my 15 diesel however had a water in fuel scare that without going into to much detail ford really took care of me and made me a customer for life!! Just seems to be to much risk vs the reward for me in these newer diesels. God they are beast mode though!!!
Old Jun 21, 2016 | 07:34 PM
  #39
System's Avatar
System
Prolocutor
Since WIF (like any other super rare diesel issue) already happened to you, you are the safest person to buy a new 6.7. Lightning striking twice and all... Don't fear the unicorn bud.
Old Jun 22, 2016 | 09:32 AM
  #40
Desert Don's Avatar
Desert Don
Also, the fact is, a gallon of gasoline can not produce as much horsepower as a gallon of diesel fuel, no matter how you roll, simply because the energy is not there. Therefore, a 500 hp diesel will use less fuel than a 500 hp gasser.
A gallon of gasoline contains approximately 114,000 BTU's, and a gallon of diesel contains approximately 139,000 BTU's......BTU's are what make horsepower!
Old Jun 22, 2016 | 09:46 AM
  #41
fordmantpw's Avatar
fordmantpw
That is the primary reason that diesel engines have typically gotten 20% better fuel economy than gassers. This has narrowed with the emissions requirements over the past 8 years, but with enhancements to regens and emissions equipment, diesels are coming back some.
Old Jun 22, 2016 | 10:47 AM
  #42
troverman's Avatar
troverman
But you also forget one other fact - diesel engines are heavy, which adds weight to a vehicle, which saps economy. More importantly, diesel engines are larger displacement and have much heavier internals - resulting in some of diesel fuel's extra energy being consumed just to overcome the additional rotating mass.
You're right, the diesels do better (see EcoBoost 2.7L economy vs RAM EcoDiesel economy) but gas turbos have other advantages they are just beginning to exploit. Manufacturers are experimenting with mixed ignition strategies...such as compression ignition for gasoline engines at certain points.
Old Jun 22, 2016 | 06:50 PM
  #43
Ron94150's Avatar
Ron94150
Wow, 6.2's are awful, gutless, gas hogs.
On my my recent 1600 mile road trip with 8500lbs, scaled, through the gorge on i40 at the TN/NC line from Knoxville TN to the outer banks of NC I averaged over 9 mpg while towing, hand calculated, not the lie-o-meter. But the meter was very close as usual. The truck had just rolled 4K miles before we left. I got stuck in the right lane behind two big rigs before black mountain opened to 3 lanes and was down to 30 mph, the truck pulled itself back up to 60 no problem(5 over the posted speed limit) and I held it to the top. Oh, and I have 3.73's. My dad has the 4.30's, and I would recommend them, mainly because city mpg is a bit better, and it's faster, but the 3.73 is no dog. 4.30's are also nice for when you put the big tires on.
Attachment 151074
And to the one that says a gas 250 doesn't seem logical to them, this load is over payload in any f150.
Old Jun 22, 2016 | 07:02 PM
  #44
Ron94150's Avatar
Ron94150
There is also a member on here by the name of flatbed Ed, he has 323,000 miles on his 6.2 with no major issues. And obviously by his name and the miles, he uses his truck. Many with 200,000+.
Old Jun 22, 2016 | 07:18 PM
  #45
Larietpsd's Avatar
Larietpsd
I think 4.30 is a must
