1978 - 1996 Big Bronco
What auto trans did '91 5.8 have??
Old 06-29-2001, 02:00 PM
johnfl's Avatar
johnfl
johnfl is offline
I have a 5.8 out of one and was told that the flex plate is wrong for the AOD. What other Auto transmissions were available that year?
JohnF
Old 06-29-2001, 06:55 PM
AlM's Avatar
AlM
AlM is offline
[font size="1" color="#FF0000"]LAST EDITED ON 29-Jun-01 AT 08:02 PM (EST)[/font][p]e4OD, iaw w/this info:
http://www.off-road.com/ford/bigbroncos/faq.html#1991
1990: brought the electronic AOD and it was now the standard auto. 300 CID and 351 CID HO engines now featured EEC-IV engine diagnostic connectors.
1991: was the 25th anniversary of the Bronco and no long-term changes were made. However, Ford did make a Silver Anniversary Edition of the Bronco available to commemorate the occasion. This limmited edition Bronco was offered only in Currant Red with gray leather interior. This was the first factory offering of leather seating on the Bronco and was only available on the Silver Anniversary Edition. The Currant Red paint was also exclusive to this edition. The E4OD became the stock automatic transmission..."
and:
http://www.baumannengineering.com/e4odinf.htm
"If the shifter has a P-R-N-OD-D-1 pattern, the transmission must be an AOD (applicable to 1980-1993 vehicles).
If a 1989-1993 truck has an Overdrive Cancel Switch and a P-R-N-OD-2-1 shifter pattern, then it is equipped with an E4OD transmission. With the possible exception of some 4R70W equipped 1993 E-150 vans with 5.0L SFI engines (The existence of a 1993 4R70W van is unsubstantiated).
1994 and later vehicles with four speed automatic transmissions will all have an Overdrive Cancel Switch and a P-R-N-OD-2-1 shifter pattern, but may have either an E4OD or a 4R70W transmission. All 4.2L, 4.6L and some 5.0L engines use the 4R70W transmission, while diesel, 4.9L, 5.4L, 5.8L, 6.8L and 7.5L vehicles always use E4OD’s. You can measure the transmission fluid pan to determine which transmission you have if identification information is not available. A 4R70W transmission pan has an overall length of just under 15 inches, while an E4OD pan is much larger, measuring about 20 inches in overall length.
The E4OD has seen many changes and updates since its introduction in 1989..."
Old 07-03-2001, 02:45 PM
johnfl's Avatar
johnfl
johnfl is offline
Thanks. Good info
Old 07-04-2001, 12:39 AM
bigfordman70's Avatar
bigfordman70
bigfordman70 is offline
Old 08-25-2016, 03:42 AM
houtslager's Avatar
houtslager
houtslager is offline
Sorry to hijack this thread, but my E-150 gas the 351W 5.8l engine and the box has a 20 bolts on the pan. So what transmission is it, and when doing a fluid change, what is the fluid I need for it? Mervin 2,3, or 4
Many thanks in advance.
K
Old 08-25-2016, 07:48 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Mark Kovalsky is offline
Received 1,576 Likes on 1,054 Posts
K
You can't hijack a thread that's been dead for 15 years.
20 bolts is the E4OD transmission.
I've never heard of Mervin fluids. This transmission needs MERCON V fluid.
Old 08-25-2016, 07:58 AM
houtslager's Avatar
houtslager
Doh ! That'll teach me to check the date on last post ��
But anyways, many thanks for the info. Now my monkey wrench can get the right fluids to give my beast some tlc.
Karl
daltonjamesadams
11-26-2017 07:18 PM
97puller
09-02-2017 10:59 AM
Efarrar
10-16-2016 09:25 AM
Austin87-460
03-24-2016 08:04 PM
xd2200
1999 to 2016 Super Duty
03-18-2016 12:18 PM
Quick Reply: What auto trans did '91 5.8 have??
