Valley drain hole
Old Jun 17, 2016 | 06:23 PM
excelstillmore's Avatar
excelstillmore
Valley drain hole
So the compression type bolt that goes from the fuel pump banjo fitting that screws down on the passenger side head fell off into the valley drain hole. My first question is can this easily be retrieved? 2nd question is will it do harm if I can't get it?
Old Jun 17, 2016 | 06:29 PM
91 Dually's Avatar
91 Dually
Are you talking about the hole in the rear near the firewall? Or do you have the fuel pump removed and talking about the hole the pump plunger goes into?
Old Jun 17, 2016 | 07:15 PM
excelstillmore
The hole near the fire wall.
Old Jun 17, 2016 | 07:18 PM
z31freakify's Avatar
z31freakify
If it went down the hole most likely is on top of the tranny.
Good luck.
Old Jun 17, 2016 | 09:39 PM
91 Dually's Avatar
91 Dually
Correct me if I'm wrong, but I believe that hole dumps out inside the bellhousing? If so, you would need to remove the inspection plate from the bottom to get at it
Guil Jones
Jun 6, 2019 10:15 AM
oldiron
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
Oct 20, 2007 12:06 AM
flyhound
Aug 25, 2005 08:25 AM
Big Red
Jun 3, 2004 06:21 PM
Rocking M
Apr 15, 2004 01:44 AM
