COWL VENT AND SEAT HEIGHT
Finally, after 3 years I was able to drive my 55 F350 Flatbed down the road, Bertha didn't run when I bought her and she hadn't ran for decades but yesterday down the road she went. However, the work doesn't end yet. The seats, which I had replaced one broken spring and then put 4" foam on the seat and 2" foam on the back, then covered it with a seat cover from LMC Trucks, the seat seemed awfully low. My wife said I looked like a little kid barely able to see over the steering wheel. So first question does anyone know what the seat height is suppose to be for a 55 F350? I assume it would be the same for a F100 - F350.
Next question, the cowl vent wasn't connected besides the majority of the parts were missing. I've found all of the parts except the curved lift arm; Midfifty calls it the "Moon" arm. Does anyone know of a template I could use to make a lift arm or where I might find the lift arm?
Still struggling with the heater fan motor.
Are your springs sagging?
Is it the original seat?
show us some pics of your seat and also of the truck!
The seats are the same F-100 thru F350 and probably up to F800, for sure up to F600. I can't believe after 4" of foam you sit too low. I rebuilt my seat and put 2" of foam and I think I sit too high.
Is the seat original? Good question. It was in the truck when I bought it but who knows if its original. I'm questioning if it is although in the seat upholstery video I watched it certainly looked the same and that was a F100 seat. Although, I can't bolt it down front and back, I can only bolt it in the back or in the front; the seat rail just doesn't reach to do both. And the LMC seat cover fit like a glove.
I'll get some pics today.
Well, tried to take a picture but my phone is doing it's own thing; I believe I've sat on it too many times.
But I did measure and my seat is 3 inches too low. I'm going to weld some 3" x 3" tubing on the bottom of the seat.
New deal: Does anyone know where the horn wire goes? I figure it must come up the steering column but don't know where it starts at. Nothing was together when I purchased the truck so I'm at a loss.
Do you have a horn wire at all? It has a special part at the horn that fits in the horn plate to keep it from falling down the steering column. When it comes out the column, it should go to the drivers side fender, to your drivers side horn, under the upper valence through some wire clips, to the horn on the passenger side. This is all I can remember off hand.
Definitely post a pic of your seat with tracks. It sounds like maybe you are missing part of the seat track? Is your seat adjustable, or is the frame attached directly to the floor?
Good info about the cowl vent. I ordered a lift handle from Mid-Fifty on Friday. I'll check fleabay and see if I can find one cheaper. When I do get one I think I'll make a template and post it on here. Probably the easiest thing to make and it seems pretty silly to pay $50 for one.
I'm going to have my wife take some pictures of the seat. The seat does adjust. But the mounting holes don't reach all 3 of the holes (two in the back and one up front). I can either mount the seat at the rear holes or the front hole but not all of the holes.
No horn wire at all. After checking my Master Parts and Accessories Catalog I found I'm missing 5 parts which I've found on Dennis Carpenter's site.
Sounds like not the original bench if the mounting holes dont line up
I'll check around to see if there is a "horn kit" MidFifty and Dennis Carpenter sell everything separately.
