Mag-Hy-Tech Covers
yes it is so. I didn't write the above debated posts.....I'm just reading them. One guy says it works and the other says it don't. I don't need to ask Mark K, who ever that is. I am just making an observing statement of what this post is telling me. I'm not arguing either side because I don't what is the right answer. And still don't know.
2015 F250 4wd. 6.2 3:73 ( plenty of power )
I'm preparing our Truck for a Florida to Alaska road trip. We'll be towing a 8k + Arctic Fox Travel Trailer. I've just ordered a new Rear Mag-Hy-Tech Diff Cover and Transmission Pan. The Diff Cover holds an additional 2 quarts of fluid. I've used one in the past and know it's worth every cent when you're towing.
The Transmission Pan holds additional 2 1/2 quarts of fluid for extra Cooling.
I've never used one of these. Has anyone ?
Is it worth it ?
Is it worth it ?
I wonder, with all the attention paid to the transmission and rear differential, why ignore the front differential?
I'd say that since you've already bought it you might as well use it. I'm sure having more fluid to distribute the heat is going to be of some benefit. Without definitive tests under controlled conditions nobody can say for sure one way or the other.
Some people will only buy stripped down XL versions on a truck while others want filly loaded Lariats. Neither is right or wrong, they see the benifit it what the pay, be it either more or less
I do a lot of work on hydraulic sysyems, part of the criteria for the size of the oil tank is the amount of heat that will be built up.
Same questions about cooling system. Why do the diesels have so much more coolant than the same size gas motor. More coolant has more serface area for more heat disipation. The radiator is larger, so yes, it will need more fluid, but what the radiator does is increase the serface area of the coolant for more heat disipation. S engine that works hard needs a larger cooling system that one that is not.
Simple question, does it take more energy to boil 10 gallons or one gallion of water? Then think of the rear dif in terms of how much heat it generates doing its job. Thin figure in that there will be heat disipation from the air around the diff.
With your logic the longer the vehicle is driven the hotter the diff will get till it boils all fluid out and melts down. The reason it doesn't is because there an equilibrium between the amount of heat generated and the amount of heat disapated.
He's the guy who designed the transmission in my truck For Ford.
If Ford could put an aluminum pan with fancy louvers and add 3 more quarts of fluid and greatly decrease transmission temps, THEY WOULD DO IT. But they didn't. What they DID do was put in larger oil-to-air coolers because that is the only part that has anything to do with transmission oil cooling. There's a reason the single most useful mod on a 99-04 gas Super Duty is installing a larger cooler, because it actually works.
This is the same argument for CAIs:
- K&N gives you 37 MORE horsepower through our better engineering of an incredibly simple and cheap air filter! We're not sure how but we totally promise this is true!
- Oh wait, OEM intakes pull cold air from outside the engine bay?
- Crap, OEM filters flow more CFM and filter to a finer particle size also?
- Hey, our filter is louder!
- Advertising!
- Take money from people who think an air filter actually adds power
#29
Is it worth it ?
Is it worth it ?
$600. for the two.
My reasoning was if I'm able to have a larger capacity of oil plus the Cover made of Aluminum, it would dissipate the heat better like the older Super Duty's had.
Kind of like having a Larger Radiator, Larger Mass, More capacity, all equals better Cooling.
But, If I really don't need them ..
#30
- Advertising!
I agree with what others have said, the Ford 5r110 is so good it really doesn't need the bigger pan.
