Need help no cranking
Old Jun 15, 2016 | 08:09 PM
FarmallM4's Avatar
FarmallM4
I've got good baterys and new starter but I havenot unraveled wireing harness the two wires on starter deltoid look good I hate to cut open a bunch of those inline fuses but will if need so but I have power to everything else as far as I can see radio,lights,a/c blower , ect. What should I do? Turn the key and all the stuff turns on except from it does not crank over no electric sounds no nothing all suggestions welcome , Thank you
Old Jun 15, 2016 | 10:35 PM
163junk's Avatar
163junk
How about neutral switch ? Wiring goes from ign sw to neutral sw then starter.
Old Jun 16, 2016 | 04:28 AM
tjc transport's Avatar
tjc transport
i ain't rite
what truck?
will the starter engage if you jump the fender mount starter relay?
Old Jun 16, 2016 | 11:32 PM
waystro's Avatar
waystro
Originally Posted by tjc transport
what truck?
I'm having the exact same problem as Op mine will crank by jumping the fender relay but the fsv isn't working
Old Jun 17, 2016 | 04:14 PM
tjc transport
i ain't rite
WHAT TRUCK?????
there are three different body styles the IDI was used in, and two different ignition systems. without knowing what you are working on, we can not help you fix it.
Old Jun 17, 2016 | 05:12 PM
bashby's Avatar
bashby
WHAT TRUCK?????
Guy walks into an auto parts store says "I need a starter for a 97 olds."
counter guy:"what kinda olds?"
Customer: "mobile"
Old Jun 18, 2016 | 09:28 AM
FarmallM4's Avatar
FarmallM4
WHAT TRUCK?????
Sorry 86 f250 6.9 idi
Old Jun 18, 2016 | 11:30 AM
tjc transport
i ain't rite
when you turn the key to start, do you get voltage to the small wire on the fender mount starter relay?
if yes, than either the fender relay is bad, the cable from relay to starter is bad, or the starter is bad.
if no voltage on the little wire, than it is either a bad neutral safety switch on automatic trans, bad clutch interrupter switch on manual trans, bad ignition actuator in the column, or a bad ignition switch.
usually on the 83-91 trucks it is a bad actuator int he column.
when turning the key to start, you should feel a slight resistance, and when letting th ekey go, it should return to run position.
Old Jun 18, 2016 | 12:36 PM
FarmallM4's Avatar
FarmallM4
If I use a screwdriver I can get it to crank by connecting the fender relay postive side to the silnoid on the fender negative
Old Jun 18, 2016 | 12:55 PM
tjc transport
i ain't rite
both large terminals, or the battery side large one to the small one?
if it will start after jumping the large to small terminal, than you need to go inside the truck to find where the problem is.
first check for a slight resistance in the key between run and start..
Old Jun 18, 2016 | 01:52 PM
madpogue's Avatar
madpogue
Wow, no one has asked - automatic or manual transmission?
Old Jun 18, 2016 | 03:32 PM
tjc transport
i ain't rite
reason i did not ask is because the neutral safety and clutch interrupter switch very rarely just "GO". they will give you warnings they are failing by sometimes working, sometimes not. a starter relay or ignition actuator will either work or not. there is no sometimes with them.
Old Jun 18, 2016 | 03:44 PM
madpogue's Avatar
madpogue
The clutch switch on the '83-'86 trucks actually goes out of adjustment very easily. It's a really cheesy design compared to the later switch mounted on the pushrod. And if it's an automatic, the OP's truck is a C6, which, IIRC, has the neutral switch on the column, which is always susceptible to maladjustment.
Old Jun 18, 2016 | 03:45 PM
tjc transport
i ain't rite
c6 nss is on the shift arm on the side of the trans..
Old Jun 21, 2016 | 06:53 AM
FarmallM4's Avatar
FarmallM4
It does have a c6 btw but
I touched the positive on relay
And negitve on silinoid and I turns over or I can touch the positive on silnoid<br/>And the small wire on silinoid and it turns over for that to
