'93 would most likely be R12, The switch to R134 came in '94, the low and high pressure valves are on the left (driver's) side, like right off the compressor, just below the oil dip stick.
If you can find a shop that "might" have some R12, you would be lucky.
Other wise, it's time to convert to R134.
There are many posts on this board dealing with the conversion.
Getting a can of re-fill from the parts store is out of the question, it will not work unless you have the system converted to R134.
