Who's done a 351/5.8 EFI swap?
Rebuilding a '95 5.8 motor...
Even tho I took pix during tear-down, I'm getting a little anxious looking at all the "stuff" that will need to go back on.
I'm just about done with the bottom end. Looking for a good manual and/or diagrams to ID everything.
Also, I'll be deleting both the smog pump and PS pump, so not sure what that means for belts??
Anyone done this swap? Hoping to simplify this EFI motor to the bare minimum necessary to run (using OEM harness and EEC module).
Thanks.
Thanks.
Thanks.
Thanks.
There is a smog pump delete idler pulley you can buy so that you always run the factory length belt. Or you can do an internet search to see if someone gives you the length belt you need and not run a pump or idler pulley.
https://lmr.com/item/LRS-9486BL/79-9...FYE9gQodIOgMVA
WaterdogF150
02-14-2024 06:48 PM
craveman85
10-15-2015 07:55 PM
kennethrasnake
09-02-2010 09:09 PM
1994 F250: 351, C6
01-23-2009 04:43 PM
