I found a Saginaw pump
I found one on a 4.9L 91 E150. 1FTEE14Y4MHA86773
I was wondering what I need to take from it to make the install on my 1981 Bronco with a 4.9L easier? Or do you think that is possible?
1.Bracket?
2.Lines?
1.Bracket?
2.Lines?
I was just thinking about this, since I'll be going out to a yard soon to look for one.
Curious about how an EFI era Saginaw PS pump would work on a carb era.
The biggest thing I could think about was the belt setup, since it'd be going from an individual V belt, to a serpentine belt.
Would just a swap of the pulley from your old pump work?
Ya the bracket I thought was going to be the hard part along with finding a E-Van with a 300 but I just kinda started to look at the pull a part and found that 91 with a 4.9L.
I think I will try it. Just figure out things when I get to the problem. I am sure there will be a few.
Research time!!
Research time!!
Well I got the pump and bracket. The bottom four bolts mount up along with one on the front of the block. Do I need to make some more effort in getting more bolts to work.
I am only running the P/S pump not the A/C.
I mean I might just need to wait until I find an older E-van with a bracket that is more in sync with my 81 300 I6.
