Different carpet?
Old Jun 14, 2016 | 03:47 PM
hot-rod's Avatar
hot-rod
Different carpet?
Hi guys,
is there a different between in-cab-gas-tank and without in-cab-gas-tank for the carpet How is the quality from LMC-capets?
Old Jun 14, 2016 | 04:01 PM
351Cleveland C4's Avatar
351Cleveland C4
No difference that I know of. And can't think of a reason why there would be.
Can't speak for the LMC carpet, but if it's like the rest of their stuff, quality isn't the right word.
I bought my carpet at Home Depot and fitted it to the floor in about an hour.
Old Jun 14, 2016 | 04:51 PM
hardlyrider's Avatar
hardlyrider
Try www.accmats.com. They make a mat for external tanks that runs farther back. There are other vendors as well. LMC doesn't make any and is just a reseller. Auto Carpet for Car, Truck, Van - Stock Interiors is another good supplier.
Old Jun 14, 2016 | 04:53 PM
MIKES 68 F100's Avatar
MIKES 68 F100
with out in cab gas tank gives you more carpet to cover where the tank would be .
LMC is just a reseller . I got my carpet from below very happy with Quality ,fit and price
Old Jun 14, 2016 | 05:00 PM
jowilker's Avatar
jowilker
If you have removed the tank from the bed, try ordering carpet for a 73-79. There was 4 in added at the rear of the cab in 73 and the remaining floor is same as 65-72.
John
Old Jun 14, 2016 | 05:15 PM
HIO Silver's Avatar
HIO Silver
Some carpets go along the rocker and don't extend under the seat and leave it metal. Others cover the floor in its entirety and extend to under where the gas tank would be.
Know which you are ordering.
The PO of '70 included new carpet which was still in the box... I pulled it out too late to discover it didn't extend under the bench and I going to install buckets... installed it anyway and now it is on my to-do list to install the correct carpet... gotta relocate the in-cab tank first though... dang to-do list!!!
Old Jun 14, 2016 | 05:22 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by hot-rod
Hi guys,
is there a different between in-cab-gas-tank and without in-cab-gas-tank for the carpet How is the quality from LMC-carpets?
The only 1967/72 F100/350's that didn't have an in-cab fuel tank were Crew Cabs or 1969/72 F100/350's with the factory in-cab storage compartment that took the place of the fuel tank.
When the storage compartment was installed, the optional 25 gallon auxiliary fuel tank became a mandatory order for an obvious reason.
You aren't going to gain any additional legroom by relocating the in-cab fuel tank. When back all the way, the lazy-back of the seat hits the back of the cab.
Old Jun 14, 2016 | 05:29 PM
Randle's Avatar
Randle
Hi guys,
The carpet without cab tank will cover all way to the back of the cab. The best buy I found is Rock Auto, they carry ACC carpet and the 100% Nylon is $108.79 and the 80% Rayon/20% Nylon is $115.79.
1970 FORD F-100 6.4L 390cid V8 Flooring | RockAuto
Old Jun 14, 2016 | 11:21 PM
HIO Silver's Avatar
HIO Silver
Moving the tank nets storage space for tools, spares, n such... that's my motivation for removing the in cab tank.
Old Jun 15, 2016 | 01:53 AM
hot-rod's Avatar
hot-rod
Many thanks for all the good tips. I think I will order directly from stockinteriors.com. BUT: which one is the right one???? This or this My bump is a 2wd with a 360 engine and a c6 transmission.
Old Jun 15, 2016 | 07:53 AM
Uni Moe's Avatar
Uni Moe
I believe if you have a C6 you need the high hump.
Old Jun 15, 2016 | 08:48 AM
MIKES 68 F100
Yup I ordered the High HUMP , fit was perfect .
I added a layer of Dyna mat (knock off) under carpet . It made a huge difference in noise in the cab .
jerryst
May 2, 2017 08:23 PM
nerksa
May 29, 2016 03:45 PM
adam83
Aug 18, 2015 07:22 PM
learpilot
Oct 1, 2011 08:53 AM
oldtexasdog
May 11, 2009 07:17 AM
