Gauges acting funny
Old Jun 14, 2016 | 09:20 AM
pwjackson42's Avatar
pwjackson42
Gauges acting funny
Okay so my temp gauge has been working off and on for awhile. Sometime you hit a bump and it will start working or give the dash a little tap and it will work. Now my fuel gauge is acting funny no matter what tank it's on, it's not reading correctly. I just installed a new selector valve so I know it is not the issue.
Question is if I take my dash apart will I be able to see if there is a loose wire or will that be a waste of time. I am assuming since you can tap on the dash and get it to work sometimes it's defiantly a problem there. Where is the ground wire located for the cluster? I cleaned all the grounds under the hood last night.
Old Jun 14, 2016 | 09:25 AM
knottyrope's Avatar
knottyrope
you need a wiring diagram and if its not working you should be able to find the open circuit faster
sometimes wiggling wires can find it if your meter has a beeping function on ohms
Old Jun 14, 2016 | 12:28 PM
pwjackson42
Would the dash switch effect how the fuel gauge is reading?
Jo7.3
20
May 20, 2019 09:07 AM
2000XPSD
Jul 28, 2015 10:50 AM
SuperDuty93
Sep 30, 2013 08:56 PM
RockaRolla
Feb 10, 2012 01:22 AM
inkpusher2004
Aug 1, 2005 05:29 AM
