Axle bearing replacement
Old 06-12-2016, 08:17 PM
Amicus's Avatar
Amicus
Amicus is offline
Gentlemen,
It's time to replace my axle bearing and hub assembly. Looking at RiffRaff site they show 3 different models. Early 99, fine course and course. I think I have the course thread but just want to make sure before I order. My truck is a L99 and I don't have the abs sensor. Looks like all 3 have come with the abs sensor. Do I simply not connect the sensor? Here's a pic of what i have. Course thread?
Old 06-12-2016, 08:33 PM
Pikachu's Avatar
Pikachu
Pikachu is offline
Yes, coarse thread. You should still have a connector on the back of each front fender liner that the wheel speed sensor will plug in to if you just want to keep them out of the way and not cut the wires.
Old 06-12-2016, 08:45 PM
Amicus's Avatar
Amicus
Amicus is offline
Thanks, Pikachu
Got stuck the in the mud the other day and I guess all the action was to much for the old hub assembly. Started making grinding noise today and had a lot of wobble in tire. The hub assembly had a lot a play in it. Everything else was replaced a couple of months ago. Thanks for the help.
Old 06-12-2016, 11:03 PM
Bonanza35's Avatar
Bonanza35
Bonanza35 is offline
Didn't know Clay sold the hub assemblies. What brand are they?
ExPACamper
17
09-08-2016 07:49 PM
Trouble1263
25
04-20-2014 09:21 AM
Piolet
04-07-2013 09:04 PM
countryboy73703
1999 to 2016 Super Duty
06-23-2011 07:13 PM
homesteader
11-17-2010 05:08 PM
Quick Reply: Axle bearing replacement
