Sponsored by: Real Truck
DEF problem
Old Jun 12, 2016 | 04:38 PM
treedriver's Avatar
treedriver
DEF problem
So my new 2016 F450 sends a message: 500 MILES LEFT ON EXHAUST FLUID............. so I fill it up and am surprised it only requires about 1 gallon.
Then I started the truck and it says: EXHAUST FLUID 471 MILES LEFT.
So I take another short drive hoping things will improve and now it says:
EXHAUST FLUID 462 MILES LEFT. Any ideas as to what's causing this?
I am not happy about the prospect of being shut down in 400 miles.
thanks for helping.
Old Jun 12, 2016 | 05:49 PM
rdlouks's Avatar
rdlouks
It sounds like the sensor is has failed. Before it strands you get to your local dealer and have it corrected/replaced. Being a 2016 it should be under warranty.
Old Jun 12, 2016 | 05:54 PM
senix's Avatar
senix
I'd take it and have it reset. It is confused.
Knowing about how many miles you have on the tank helps.
Old Jun 12, 2016 | 06:34 PM
treedriver's Avatar
treedriver
Thanks for the replys. The truck has 1806 miles on it.
Old Jun 12, 2016 | 06:37 PM
senix's Avatar
senix
once reset don't fill again till it gets around 200 to empty. Then do a complete fill. That has been the best way for me.
Old Jun 12, 2016 | 08:00 PM
RainDesert's Avatar
RainDesert
thanks for helping.
1 gallon wont reset the stupid sensor. I had this problem on my '14. Try putting 2.5 gallons in, worked on mine.
Old Jun 12, 2016 | 08:26 PM
treedriver's Avatar
treedriver
one gallon is all it was able to take. It is full. It was only down 1 gallon when the 500 mile message went on.
Old Jun 12, 2016 | 08:31 PM
RainDesert's Avatar
RainDesert
Oh ok. Like said, probably a bad sensor or maybe some reset at dealer can be done.
Old Jun 13, 2016 | 03:20 AM
rdlouks's Avatar
rdlouks
Keep us posted as to what the dealer finds.
Old Jun 13, 2016 | 05:21 AM
cyncwby's Avatar
cyncwby
While were at it, how many miles of "normal" driving does a tank of DEF last? I just hit 1100 miles on mine.
Old Jun 13, 2016 | 05:23 AM
senix's Avatar
senix
normal unloaded def should last upwards of 7500 miles. About the length of the oil change.
Loaded I see around 4500 miles.
unloaded is more regens and less def.
Loaded is the opposite.
Old Jun 13, 2016 | 07:34 AM
rdlouks's Avatar
rdlouks
Is this due to when loaded the exhaust stream is getting hot enough to go into "Passive Regen" when required?
Old Jun 13, 2016 | 08:20 AM
bigc1301's Avatar
bigc1301
how do you see the mileage left of the def?
Old Jun 13, 2016 | 08:40 AM
RainDesert's Avatar
RainDesert
Mine was a '14 XL. A message would show up on the cluster screen when I hit the 500 till empty mark. It would stay on until I filled it with at least 2.5 gallons.
Old Jun 13, 2016 | 09:16 AM
senix's Avatar
senix
Yes, most of the time when I tow my exhaust filter percentage stays at 0%.
