Sponsored by: Real Truck
brakes pulling left
Old Jun 12, 2016 | 04:10 PM
stomperrzr's Avatar
stomperrzr
brakes pulling left
Need some help guys for last couple years been having problems with front brake calipers locking up and after i replace with reman work for 6 or so months and then they stick again . I have now bleed all fluid out put new in along with power stop calipers along with sliders that are rebuilt new pads with new rotors and new lines to hard line and the truck is still pulling left does anybody know if the abs box could cause an issue.
Old Jun 12, 2016 | 07:44 PM
jetjockey99's Avatar
jetjockey99
Have you replaced the rear calipers? They can cause a brake pull also. It also sounds like the push rod from the power booster to the master cylinder may be just a few thousands too long not letting the master cylinder fully retract and holding a slight amount of pressure on the front brakes.
Old Jun 13, 2016 | 02:06 PM
stomperrzr's Avatar
stomperrzr
brakes pulling
No I have not thought about checking the rear calipers I just figured it was front calipers
2006lariat
Sep 10, 2014 06:58 PM
hownottodrive
1997 - 2003 F150
Jun 10, 2013 11:23 AM
fordtruckman03
Aug 27, 2011 10:57 PM
dewdrinkinmutha
Mar 20, 2006 09:13 PM
kman2785
Feb 4, 2003 09:15 AM
