Black smoke when starting.
Old Jun 11, 2016 | 12:44 AM
Rawo Walles's Avatar
Rawo Walles
I have a 89 F-250 with a 351w. When I go to start the engine it blows a little black smoke out the exhaust. Is it cause of old oil? I recently bought this truck and I use it around a farm. I dont know the miles because the dash cluster dose not work. It will only show the RPMs. Anything similar happen to anyone else?
Old Jun 11, 2016 | 09:48 AM
bmxerbrett's Avatar
bmxerbrett
I would guess it's from unburned fuel during the startup process. I wouldn't worry about it.
Old Jun 11, 2016 | 12:53 PM
'89F2urd's Avatar
'89F2urd
Is the check engine light on? How does it run?
Old Jun 11, 2016 | 03:30 PM
JKNW's Avatar
JKNW
Black smoke is unburned fuel, most likely you have an injector leaking down while the truck is sitting.
Old Jun 11, 2016 | 07:09 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
X2 on this..
Old Jun 11, 2016 | 07:47 PM
'89F2urd's Avatar
'89F2urd
Yep that's where I was heading.
Old Jun 11, 2016 | 10:29 PM
Rawo Walles
It runs fine. It has trouble starting due to solenoid/relay or starter issues. But yes the check engine light is on. The wiring is a mess under the hood, but im really not concerned about that. Ultimately i have other plans for the 351. I was just curious if black smoke was particularly bad for the engine.
Old Jun 11, 2016 | 10:32 PM
Rawo Walles
It dose run fine. Check engine light is on but thats because the wiring under the hood is a nightmare. Also because it was originally an automatic C6. Now it is a 5 speed ZF S5-42.
Old Jun 12, 2016 | 02:05 PM
JKNW's Avatar
JKNW
It's not great for it, if there's an injector leaking down that means that it's also washing away the oil that lubes the rings.
Old Jun 12, 2016 | 04:19 PM
87 XLT's Avatar
87 XLT
On most Fords checking fuel pressure is as simple as checking tire pressure. Screw on a gauge start it up turn it off & see if the pressure holds steady. If it does'nt something is leaking
Old Jun 12, 2016 | 05:30 PM
'89F2urd's Avatar
'89F2urd
You can also do a hard downshift engine brake test. If you downshift to ~3000 rpm and let the engine slow you down there should be no fuel injecting, so if it stumbles and pops and is not smooth, you have a leaking injector. In a downshift, it should be smooth as though the key was off.
Old Jun 16, 2016 | 09:35 PM
Rawo Walles
Ok, thanks. This has been helpful. Curious question. How do I show my vehicles and specs under each post?
Old Jun 17, 2016 | 12:19 AM
Lead Head's Avatar
Lead Head
You add it to your signature in the user control panel.
Old Jun 17, 2016 | 06:20 AM
My4Fordtrucks's Avatar
My4Fordtrucks
The PCM doesn't control a C6 and wouldn't know you now have a 5 speed.
What codes are in the system?
kystangbanger
Feb 25, 2009 03:45 PM
Hellonwheels
Jan 17, 2008 09:11 PM
Mat Dope
Bio-diesel, Propane & Alternative Diesel Engine Fuels
Nov 21, 2007 10:46 PM
GPSMatt
Nov 4, 2005 08:55 PM
3greenfordsagain
Aug 27, 2004 12:19 PM
